Hi I have a John Deer L110 with Kohler command 17.5hp engine. Fault is it wont start but backfires and stalls the starter mower as though its firing against the compression - I see others have had the same problem - is it timing?
This model is known for shearing the flywheel key.
Testimonial: "Just as you said - flywheel key had sheard, an easy fix thanks very much."
Ther is an anti back fire solenoid in the front of the carb that you need to check or replace,if the wireing to it checks ok[12volts in the run position].If this is not the case then then the valves need to be adjusted so that the decompresser works normally.
Testimonial: "thanks heaps - i'll give it a go"
I washed the engine and after that it won't start and is back firing
How to check auto transmission fluid
