Garden Logo
Posted on Nov 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After running for 20 to 30 minutes, engine looses power and stops. Will start up again immediately. Recently replaced spark plug, air filter, fuel filter and an oil change.
Roland W VanLue
Level 3:
  • Master 486 Answers
  • Posted on Nov 12, 2009
Roland W VanLue
Master
Level 3:
Answers
486
Questions
0
Helped
315198
Points
1454
This type of issue has 3 possible senerios. In 35 years, I have experienced each of these by themselves, or sometimes multiples at the same time. This is a tough issue, but can be resolved with enough patience and a test area.
#1 Fuel Related
Depending on make and model of mowers:
a) Fuel tank outlet plugged (some have a screen filter, some are 90' angle and plug with rust and debris inside the corner of fitting)
b) Fuel lines collapse when they are routed thru fasteners and between frame and seat decks
c) Fuel cap vent clogged
d) Fuel filter clogged
e) any fitting that has an orifice that can trap debris or rust will eventually become clogged
f) fitting on the side of the carburetor
g) some systems have a filter inside the line at the opening of the carb inlet
h) fuel pump
i) vacuum hoses to fuel pump
j) debris under inlet needle/seat on carb
#2 Ignition related issues due to time and heat
a) Flywheel looses magnetism (not too common, but does happen)
b) Ignition switch or circuit breaker overheating
c) wire connection on plug-ins to switch or wire harness
d) points/condensor breakdown
e) ignition/armature coil
f) spark plug wire
g) electronic trigger/coil overheat
#3 Exhaust Valve and/or sticking due to overheating
a) valve stem is coated with excess carbon
b) valve face and seat are worn and do not seat properly after becoming warm
c) valve clearance too tight
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
2helpful
I have a Tecumseh engine on my Troy-bilt snow blower. It starts right up and will run for as long as five minutes and then dies. I have taken off and cleaned out the fuel tank, installed an inline fue
First try running it with fuel cap slightly loosen as the air vent in the cap be plugged creating a vacuum on the tank. If you engine continues to run for 10+ minutes when this is done replace the fuel cap.
Next when the engine dies immediately check for a full fuel bowl if empty or nearly empty then you still have a fuel flow problem.
This can also be an ignition related problem where the electronics in the ignition coil has a thermal failure. You check this by checking for spark immediately after the engine dies. If no spark I would first replace the spark plug as they can fail under compression load and try again. You still having failure then the next next to do is replace the ignition coil pack.
Why is my Toyota LC not accelrating beyond RPM 3.
try to reconnect the check engine sign (make the OBD system operative), it looks like the fuel injetion calculator is not working properly
3answers
Car will start sometimes other times i will have to continue to crank the engine it cranks everytime
As it cranks, is there white or black exhaust smoke ?? If yes, the fuel injectors have solid build up on the tips. Normally, a quart bottle of injector cleaner treats 20 gallons. Pour 5 to 7 quarts of fuel injector cleaner. With cold engine (been parked for at least an hour or overnight), while cranking engine, have 2nd person spray starting fluid into air filter. DO NOT PRESS ON GAS PEDAL !!! Let the starting fluid do its job of starting the car. Starting fluid is highly combustible, so its important you don't give any gas while its cranking and 2nd person is spraying into air filter. When engine starts, stop spraying starting fluid and give a little gas. If engine begins to die, immediately spray a little starting fluid again. When engine begins to run, let it run a few minutes to let fuel injector cleaner to do its job (loosen solid carbon build up on tips of fuel injectors).
Toro Timecutter 14.38Z Model 74301 Briggs & Stratton Engine Model 280H07-0166-E1 Has NIKKI carb Starts & runs for ~ 15 minutes then stops. Will restart after 5 minutes rest and run...
Recheck spark when the unit cuts out. I am gonna guess you spent a lto of money chasing a bad coil! When a coil starts to go bad they become temperature sensitive. Time does the rest!
Dec 27, 2012 • Garden
B &S 16hp engine on a riding lawn mower. Engine model #303777 Type 0015-02. 420 hours on tach. Under load engine hestates and dies. Will restart immediately, run a few minutes and die again. Without...
check the fuel cap too,, it needs to be venting for better fuel flow, also,, when was the last time it got plugs,, it may be flooding out due to weak spark
Jul 07, 2011 • Garden
Have gts toro, engine starts then stops can not get it started.. r s
Your mower engine has to have these things WORKING to run: 1. Compression (engine in good shape) 2. Strong Spark (magneto air gap has to be correct for strong spark) 3. Clean air ( good, clean air filter w/no air leaks) 4. Clean, fresh fuel supply (gas less than 30 days olds with an inline filter installed in mower's fuel line). These things are assuming the mower hasn't struck an immovable object such as concrete, tree stump etc. recently. This will shear the flywheel key and timing may be off so far that engine won't start. So, where would you like to start my friend? Try checking these things. In the meanwhile....we can try to "coax" the engine into running. Remove the spark plug. Get an aerosol can of carb/choke cleaner spray. Spray a couple of shots into the engine. Reinstall plug. Choke the carb and attempt to start. This may or may not work, according to the conditions listed earlier. If this doesn't get it running, remove the plug and try it again.
We are trying to get it to run on its own, so it will start (or attempt to start) drawing fuel from the carburetor. Sometimes the brass bolt that holds the carburetor float bowl on gets clogged. You drain the gas, remove the bolt and clean all the small hole in the bottom and along the sides of it. This bolt is also the main jet of the carb. Cleaning this with carb cleaner can only help. If you do this, use NO metal objects to poke or scrape the bolt. The holes are metered and have to stay that way. Check for spark, check your air filter, see if the plug gets wet after you attempt to start. If it doesn't get wet or even smell like gas, then likely you have a fuel flow problem. Try ALL these things and post back; and again, if you have hit something solid recently with the mower, you will have the replace the flywheel shear key. It is a small aluminum $1.00 part so don't worry. Post back as needed. We wish to help.
Cub 1550 with kohler courage. Runs fine and then loses power, runs erratic and starts to backfire. Cleaned carb and fuel pump and ran fine for 30 minutes and then problem started again. When this occurs,...
Replace fuel filter after cleaning tank thouroughly, to clean tank remove fuel line at carb. Drain all fuel then leave line loose until you flush tank with carb. Cleaner then blow out tank with compressed air. Now install new fuel filter and check your fuel can for trash and water better yet just add fresh fuel.
Aug 12, 2017 • Garden
2001 mitsubishi galant stops running after ten Minutes
This is either loss of spark or fuel.
Try running the car with the gas filler cap loose. This may induce a Check Engine Light which you can ignore, but will test if the fuel system is cavitating. If the problem goes away, then there's a problem with the evaporative return system, or a clogged fuel filter. Since its a 2001 it's unlikely to be a fuel pump. Don't be persuaded that this is the problem unless there is definitive evidence, such as low fuel pressure.
If the engine starts again immediately after the stall or after a few minutes, the problem is likely to be (one of) the ignition coil or ign power transistor.
Why wont my chainsaw tick over, it revs up but not tick over. also, cannot start it after 2-3 mins of usage, why?
Check the air cleaner and muffler for plugging. Try turning the idle speed screw (not the L jet screw) CW one full turn. Does it now idle? If the chain keeps turning at idle, back off the speed screw until the chain stops after revving the engine. When the engine won't start, remove the spark plug and check for blue, snappy spark. If the plug insulator is black, try a new correct type plug. If sparks ok, then squirt some fuel mix into the plug hole, replace the plug and try to start. If you get a pop or two, then fuel delivery is a likely problem. If it again runs, the plug may have been the problem. Otherwise, check the fuel filter, fuel line, and carburetor for any loose fasteners. Finally, run the engine at full throttle--it should 4-stroke with no load, but immediately 2-stroke when cutting. Adjust the H jet needle to achieve this. hope this helps!
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
