We have a Frigidaire front load washer machine, model FWT449GF. An extreme vibration comes in Spin cycle. It makes the building vibrates. We are very anxious. Any solutions for me?
Thanks
André Rivard
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Will the shock absorbers cause it to damage sensors
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
When
bad...
Washer Problems
Washer
noise
when spinning
heatman101
