Hotpoint First Edition WMA12 Front Load Washer Logo
Posted on Jan 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The water will not drain on my first edition wma 10 hotpoint washing machine so does not spin either any clues to where the filter is???????
Please help
GORDON'S APPLIANCE SERVICE
Level 2:
  • Expert 283 Answers
  • Posted on Jan 06, 2008
Expert
Level 2:
Answers
283
Questions
0
Helped
147307
Points
733
Most likely something stuck in the pump. Remove front panel and hose that goes into pump. usually you will see the object. if not remove pump and look inside.
2helpful
How do we empty the filter on hotpoint first edition wma 10?
Remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose, reassmble and test for leaks.
Have some cloths ready to mop up any water that may appear..
I have a wma 10 which is a couple of years old. The door seal now leaks when the machine goes onto a spin? Is there anything that you can suggest?
Sounds like there is too much water left in the drum as it goes into the spin cycle, and the centrifugal force of the drum spinning is forcing the wate past the door seal probably, needs the filter cleaning, or the door seal itself may require replacing.
9helpful
Our hotpoint WMA22 washer will fill with water and wash but will not drain.i have lowered the drain hose to almost ground level and it will empty the water, and then will spin. In your opinion is it the...
Sounds like a blocked filter to me.
Remove lower rear panel of washer, remove large black hose fastened to bottom of drum, remove and clean filter inside hose, check pump for blockage at same time. You probably will not need to replace any parts
Please rate my solution.
Thanks.
Few12 will not spin after washing, any ideas
Had the same problem. Removed the kick plate at front and unscrewed filter. In the filter recess I found a cotton wool bud. Appeared to have stopped the blade like fan spinning which appears to push the water into the drain hose. Works perfectly now.
2helpful
Wont drain water
inside hose at back ,take back lower panel off black hose filter inside.
I have a hotpoint aquarius 6kg washing machine, i need to cancel a progeamme and drain the washing machine as their is a sleeve caught in the door and water is coming out but don't know how to please...
hiya
if the model starts with wm then you should set the timer knob just before a spin setting and it will empty out.
if the model starts with wma,few or wf then you will have to hold in the start button as this will cancel the current cycle and should start to drain.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
2helpful
2answers
Not draining and flooding my kitchen!
hiya
first off norah, you will need to check the pump filter as there is probably a blockage in there.
secondly guest, sounds like a faulty pressure switch or even a small hole in the pressure pipe, thats why your machine will not stop filling.
hope these help
please dont forget to rate the helpfulness of this reply thanks kj
1helpful
3answers
My washer does not drain all of a sudden
If you're washer is working (water in-coming, then agitiating, but does not drain/spin at the "spin cycle"; the typical problem is either the door/safety switch or the electric water pump (belt drive machines). I would test the door switch for continuity; replace as necessary.
2answers
Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
4answers
Cleaning
I am not familiar with this machine's model, but in most of the machines the filter is located under the panel in the bottom of the machine (the panel under the front door). You should pull the panel out and you will find the filter there. Before openning the filter prepare a bowl and a floor cloth to avoid water's flooding. Good luck!
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
