Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman LT2000 transmission won't engage
My Father-in-law died last week and I'm here trying to help my Mother-in-law. I've never used the Craftsman LT2000 before, but reading through the instructions (on the mower) and filling up the gas, everything worked. Emptied the collection system, went back to where I had left off, put in the clutch engaged the blades, then pushed on the forward pedal and get a grinding sound. Won't engage!
  • Roland W VanLue
    Roland W VanLue May 11, 2010
    Is the parking brake applied? If it is a hydro, do not use the brake pedal at the same time you try to move the forward motion lever or pedal
    Scholar:
  • 81 Answers
Sounds like you either lost a bearing inside the transmission or that something in the linkage system has come loose and shifted. easiest way is to jack the unit up and visually follow the shifting hardware, while having someone trying to engage it with unit shut off and see is you can visually find where the shaft is slipping or failing to move. Hope This Helps Don
Posted on Nov 10, 2009
  • Rick Harris
    Rick Harris Mar 27, 2019
    Mine doing same thing. It worked last season, but i did take right rear wheel off to get new tire last week, otherwise i have no idea how a transmission could go bad just parked in a garage.
I have a 2011 Craftsman LT2000 Model # 247.288851. The blades will only engage when I raise the deck to level 5. Ive replaced the Seat Safety Switch so Ive eliminated that. Help please! Lol
what actually engages the blades an electric clutch or a manual lever both of my craftsman mowers have elec clutch and when you pull the button the blades run deck height has nothing to do with it .
Apr 08, 2015 | Craftsman Garden
Why did Craftsman LT2000 stopped moving? Engine starts and blade engages fine.
The transmission drive belt is a separate one from the blade belt. The clutch pedal when released puts tension on the transmission drive belt so it tightens up and drives the gearbox pulley by way of a large spring. Make sure the spring is ok. The belts don't last forever and probably needs replacing looking at the age of the machine. That is a fun job as it is right up under the machine and runs from the engine pulley right back to the top of the transmission. You have to drop the deck right off and I usually find a tree with a large branch and haul the front up with a rope or winch so the mower is vertical. Makes it easier to work on. Drain petrol first though. Hope this helps otherwise get a mower shop to do it for you if you feel it's to much of a task. Good luck.
May 19, 2014 | Craftsman Garden
How do I get my Craftsman LT 2000 to not die?
check for blockage in main jet in carby.
Jun 13, 2013 | Craftsman Garden
How do I get my craftsman lt2000 to not die?
safety switches need to be replaced
Jun 13, 2013 | Garden
Blades won't engage on sears lt2000 riding tractor
check the transmission beltfor tension also the deck belt
Aug 13, 2012 | Sears Garden
We have a craftsman garage door opener Model: 139.53876, FCC ID: HBW1162 the battery died in the remote and we changed them, not sure if this changed the code but it won't open, my father in law changed...
Changing the battery should not reset the code. Check that the battery is inserted the right way round. If the battery 'died' the metal terminal contacts inside the remote/ keypad may also be dirty. You could try gently scratching the surface of the contacts with a small screwdriver to restore brightness if they are discoloured.
Feb 15, 2011 | Craftsman Drills
My Father in Law passed away and I am trying to get his Craftsman 5hp wood chipper running so that my Mother in Law can sell it. It has electric start. I assume with electric start there must be a battery...
You can visit the Craftsman website to get this info. You will need your Model Number and Serial number to download an owners manual. The manual should show you where the battery is.
Apr 19, 2010 | Heavy Machinery
Sears Craftman LT2000 does not start
bad safety switch one under seat ,clutch pedal,blade engage leaver
Sep 01, 2009 | Garden
LT2000 had been working fine, but trying to start
Make sure there is no corrosion on the battery terminal connections and check the fuse and safety switches clutch, brake,seat.
Eric
Jun 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
2,312 people viewed this question
Top Craftsman Garden Experts
john h
rjivaro
Marvin
Marvin
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
