Just the bulb.. write down the model number of the unit and they will give you the same bulb that you need, just give them the model number.
If you are going to install the bulb just remember DO NOT HOLD directly the bulb, use any clothe or gloves, because even a fingerprint can busted the bulb even thou it's not yet use
Testimonial: "Good quick response. But I don't even know what part of the tv to open to replace this part."
I would not replace just the bulb, I would replace the whole lamp. for just a little more get the whole lamp, the lamp is the bulb with the housing. I got mine on this website. www.foxlamps.com you will save time and money
1.Remove the lamp cover by pushing two grooves lightly with the flathead
screwdriver. You can see the lamp cover on the top of the projector. ( left side of the lens)
2.Loosen the two screws securing the lamp housing until the screwdriver
goes into a freewheeling condition. The two screws are not
removable
3.Remove the lamp housing by pulling out the handle
4.Insert a new lamp housing until the lamp housing is plugged into the
Socket
5.Secure it in place with the two screws.Be sure to tighten the screws.
6.Reattach the lamp cover
7.Snap the lamp cover into place.
Replacing a new lamp automatically clears the lamp usage hours
ok
