The lower hinge on each door
may have a door closing cam. It raises the door up ¼ inch when opening and this
assist in closing the door. If it’s wore out and doesn’t work the door may not
seal and the gasket can be damaged. Watch the operation of the door to see if
it rises up when opened.
Leave the door shut and let the magnetic gasket hold the
door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of
order of removal of parts. Slide new cams on.
Part 11 on this diagram is your door closer http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170924&diagram_id=1335988#d1335988
On the bottom of you door where the hinge is you shuold have a door closure. this peice may be broke if so replace it.
