It is telling you, your machine has a problem you need to tell me what program are you putting it on. if you put it on a spin only and it keep going round What you need to do is turn the machine of and open the door leave the door open and put the machine back on set the program to the spin only and then shut the door press start do touch the machine till its finished that should help Its called a reset. if you have the same problem get back to me and i will help you ok.
I have the same problem, selector knob keeps spinning. Opened the filter etc & cleaned it out, made sure the propellor blades also turned. Problem still persists. Anything else I need to do? Thanks
open the filter on the bottom of the machine (water will empty out). Clear any blockage.
I put it on program number 8 and after a while in this cycle it then spins the switch
