Hi ,
For some reason the timer delay (green) led and the door lock (red) led are flashing rapidly. I can get the machine to fill with water.and empty. and i can get the machine to spin for about 15 seconds. after that the machine stops and the leds flash rapidly. I;ve cleaned the pump chamber out. Please help
Sounds like module prob,EMW fixed mine for £40 tel01159652118. BOB
Hi Guest
"Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps"
How did you remove front from door?
Hi
I have the exact same problem as described above. Am living in Dublin , anybody know who could fix this for me?
I have this problem too. It just happened at the weekend. No idea how to fix it, so I had to call indesit to send out a service engineer. The standard cost is 114 euro. I live in Ireland and the machine is out of date.
i hve the same problem with flashing red door light and stain remover and extra rinse flashing any ideas
