The bottom off the print roller might be misaligned or worn. it could also be part of the print head is out. put electrical tape on the part that is not printing correctly and see if that improves the printing. If it does, it is the print roller. If it does not, it is the print head. Please let me know if you need any other assistance.
[email protected].
www.overstockme.com.
Jeff Watson
Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
According to your problem you can't print properly with your printer.
First check your printer cartridge is not blank. If any cartridge is blank then it may happens.
clear the cartridge head.
Cartridge may need alignment. Go to the printer preferences and select the Ink cartridge alignment.
You can reinstall the driver also.
Use dry and proper size of paper which is supported by the printer.
