try rotating the container part 1/4 of a turn to line up slots and press down . then if it does not blend turn another 1/4 turn to line up slots and press down pushing container into base motor unit .
container and screw on blade lid is put in upside down and the plastic posts have to match the base unit to turn on the blender when you press down on container into base unit.
Put the pitcher in the freezer for an hour, boil water in a pan bigger than the base of the pitcher, take the pitcher out of the freezer and stick just the base in the hot water up to the top edge of the base.. Remove it after about 15 seconds and have someone with gloves on screw the base off the pitcher
Link, Can you tell me what brand your blender is? This is usually found under the blender base or right on the front where the buttons are. Then we can tell you whether there are replacement parts or not.
This can be coming from discoloration and/or food acting on the rubber gasket. Be sure to take the pitcher apart, removing, the screw on base cap, the blade mechanism,and the gasket to clean your blender after each use. Acids and liquids can act on the rubber causing a discoloration and this will seep into your pitcher. This should take care of your problem. If it does, please come back to Fixya and rate my solution!
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks. Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it. I hope this helps. If it does, please come back and rate my suggestion!
If you remove the blinder base where the blades are you can put it all in the dishwasher. To do this grab the handle on the pitcher then unscrew the plastic base from the glass. make sure that you look how it comes apart first. then put in the dishwasher to clean. Then reassemble the way you took apart.
The blender we bought called that piece the measuring cup, It has increments measuring liquid by the ounce. I am not trying to over simplify but the manufacturer whether on line or on the phone often they have a replacement parts list. The web is the best place and usually has the list attached to the model.
