Powerline 200Watt DC to AC inverter (0900-35) Power Supply Logo
Posted on Nov 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an inverter, then a UPS, as the inverter does not always keep the PC on. The inverter does not power the UPS so it cuts out after a few mins, I then have to take the UPS out of the system until the power comes back on?
Sheldon Dedek
Level 3:
  • Master 912 Answers
  • Posted on Aug 30, 2010
Sheldon Dedek
Master
Level 3:
Answers
912
Questions
0
Helped
306539
Points
3298
As I understand your statement, Your inverter (Powerline 200watt) has the UPS plugged into it, but it is not able to keep the UPS powered on. You didn't mention the size of the load (PC), nor the wattage rating of the UPS, or the batter bank size that supplies the inverter.
It sounds like you are trying to create an electrical system with double redundancy. If this is the case, you are going about it wrong. Most inexpensive inverters will have a Modified Sine Wave output, that the UPS will detect as a poor AC signal, and revert to backup mode, rather than pass the inverter power to the load.
200 watts isn't going to be very much for anything. 200watts / 120 volts (assuming 120vac system) is only 1.6amps or so. The charger on the UPS will likely use this much just to keep the internal battery topped off. As the PC is turned on, and the battery charger is doing its thing, there now exists an overload at the inverter. The inverter will respond by trying to increase its output by lengthening the pulses in the MSW waveform. The UPS then sees this, interprets it as bad power, and kicks into backup mode.
Since the powerline inverter is obviously a 12volt unit (cig. lighter plug), then check the battery configuration of the UPS itself. If it is 12volts as well, then you may be able to connect the UPS directly to the batteries that were powering the inverter. Note that some modification to the UPS will be needed if there external battery connections are not already present. Even then, there is no guarantee that the charger in the UPS will be able to charge the internal plus an external battery bank.
Since the battery that powers the inverter is likely larger than that of the UPS, why not run the PC directly off the inverter itself and forgo the use of the UPS altogether?
APC 800va inverter is not charging
Yadava,
If you need pricing on a new or replacement unit I can help. You may also want to look into APC's Trade-Ups program where they give you a discount on new equipment as long as you provide a serial number for your existing: http://buy.apc.com/commerce/storefronts/tradeups/
If you need UPS, Surge, or Power Related help contact:
Inside Service Sales
Daniel Salazar 800.260.2259 [email protected]
Power & Systems Innovations, Inc.
[email protected]
Power & Systems Innovations, Inc. is an Elite Certified Service
Sales Partner for APC/MGE brands manufactured by Schneider Electric
Visit us at www.psihq.com
tip
Benefits of a UPS (Uninterrupted power supply
We all use many devices and equipments that run on electricity. For all these to function properly they need uniform power supply (constant flow of electricity). As the electric supply in many countries is not uniform there is a need for a device to correct it. There are many such devices available in the market today. For example UPS (Uninterrupted power supply), Voltage Stabilizer, Constant Voltage Transformer are such devices available today.<br /> <br /> <b><u>Why buy a UPS?</u></b><br />We can never guarantee that we will get constant power. The power supply always has fluctuations. Surges, Spikes, Brownouts, Blackouts and Noise can damage your electrical appliances especially your computer. To prevent this from happening you need a device that does power conditioning. Electricity has to be uninterrupted. If the voltage is higher than the specified level then it is 'Over Voltage'. If the voltage is lower than the specified level then it is 'Under Voltage'. Both Spike and Surge come under 'Over Voltage' category. But there is a small difference between spike and surge. If there is very high voltage for an instant but comes back to normal immediately then it is called 'Spike'. If there is very high voltage for a slightly longer period then it is called 'Surge'. If the voltage is dangerously reduced to very low within a short period of time then it is called 'Brownout'. When this happens, the computer can be seriously damaged. If the power supply is totally cut then it is called 'Blackout'. Noise can mix with electromagnetic or radio waves or any signals. This is called 'Line Noise'. This may also reduce the voltage level to very low within a short period of time.<br /> <br /> <b><u>How can the UPS provide power when the main electrical supply is cut?<br /></u></b>A UPS has an internal battery. With this battery charger, an Inverter is also present. The inverter converts the 'Direct current' supplied by the battery to 'Alternatinc current' as required by the computer. When there is electrical supply the charger in the UPS charges the internal battery. When there is a power cut, the battery kicks in to supply the DC which is converted to AC by the inverter and power is supplied to computer.<br /> <b></b> <br /> <b><u>What if the battery loses its power?</u></b><br />When there is power cut, the required power is taken from the battery. Therefore the battery keeps losing its capacity. If the power supply comes back before the battery is depleted then the battery charger will start recharging, but if the power supply doesn't come back then the battery keeps supplying until it totally drains out. When the battery drains below a certain level the UPS sounds an alarm for your to shut down your computer and turn off the UPS. Some UPS' even have a built in system that shuts your computer down for you after a certain amount of UPS uptime.<br /> <b></b> <br /> <b><u>How long can the UPS provide power when there is a blackout?</u></b><br />This all depends on the specifications of the UPS and the requirement of the computer. A 600vA UPS for example can supply power to a computer with a 550W power supply for about 10 minutes or more.<br /> <b></b> <br /> <b><u>Tips for buying an UPS</u></b><br />The backup time of your UPS is the most important you need to consider. Other than that, you should know how many KVA (Kilo Volt Ampere) your UPS has. A computer needs atleast 0.5 KVA (500VA) to function. If you are planning to connect more than one computer to a single UPS then you need to get one with a higher KVA.<br /> <b></b> <br /> <b><u>What type of battery does a UPS use?</u></b><br />UPS uses <b>SMF</b> batteries (Sealed Maintenance Free). These type of batteries can be used for 5 to 7 years continuously.
on Mar 05, 2011 • Computers & Internet
1helpful
2answers
GE LP33 UPS inverter failed to start
Dear Yared,
Did you try to give the UPS some time to recharge the batteries?
Seems like the batteries have reached their cut-off voltage and are not supplying enough voltage to the inverter.
Normally the dc boos circuit of the UPS will supply voltage to the DC BUS so maybe the problem can be found in the dc boost circuit or BUS if recharging the batteries is not helping.
Let me know.
Best Regards,
Ron
My inverter is not working
i have the same problem!!! my uncle got this zebra ZUPS-512 from japan together with the iMac. When the power cuts off so the computer and the UPS keeps on beeping (meaning the power is not enough and it's about to shut). My uncle knows the problem just this morning and is kinda angry wondering what the hell is happening with the UPS. I somebody here could help us.! :(((
Samsung SynchMaster 191N Monitor stay on fine for 15-20 min after that it goes dark,, and power swtich thrun itself off, cannot turn on or off, unless I unplug power for few min and replug. Then stays...
If the OSD has display and after a min goes dark that monitor has 2 possible problem. 1. bad electrolytic capacitor from secondary power supply to inverter area or fault semiconductors around inverter area. 2. Bad CCFL or fluorescent lamp of lcd panel it may be reddish color.
4helpful
2answers
How to charge ups for pc's
Your PC connection must always come via UPS, and your UPS will always keep charging.
UPS Power cable should be connected to DC, and your PC power cable should be connected to UPS.
And this way your PC will always be safe.
Is there any problem connecting Inverter and UPS in series for backup to computer?
Why would you want to do this?
The UPS has it own battery and inverter and can supply power to the computer/server and if the power interruption is too long and the battery power is unable to maintain power to the computer/server, it can initiate a shutdown procedure so the computer/server can shut down in an orderly fashion without losing data.
The size of the UPS with its batteries and the power requirements of the computer/server can be calculated to give a a capacity from as little as 30 mins to hours.
There is no need to run a separate charger, batteries and inverter to supply power to an UPS (it has all these buint-in) and it is an unnecessary additional complication.
10helpful
2answers
6helpful
Overload light in APC RS 800 UPS
it seems that the inverter circuit of your UPS is dying. the solution here is you have to open up the UPS and check the inverter circuit. to make easier, check the power mosfet if its leaking.
Top Powerline Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Powerline Computer and Internet Expert? Answer questions, earn points and help others
