This would only happen if you did not install the brake cut off switch. You will be able to shut the car off with the key after 15 minutes or with the remote.
Testimonial: "Thanks for the help, It solved my problem. "
I have a proble with my bull dog security system my car my car dosen"t star its a big problem i think because im turn on the lights and tha car die..
CAR NO START PROBLEMS:-----
It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue.
From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:-----
What to Do When Car Turns Over But
Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
http://www.howtorepairguide.com
These will help.
Thanks.
