Question about Maytag MFD2561HE Bottom Freezer French Door Refrigerator
My 2 month old Amana Refridgerator with Freezer on
My 2 month old kenmore Refridgerator with Freezer on the bottom (all doors, no drawers) is eminating a foul odor from the back exaust vent. I have made sure, and cleaned everything in the fridge, and nothing is spoiled. It smells really fowl. And nothing is spilled under the fridge either? What gives? Model # 596.75934404
    President:
  • 1,218 Answers
If your sure about spoiled food. Spoiled lemons are one of the worst, and the machine has not been abused, it's a problem of the selling dealer. Fan motors have been known to create an odor when their windings start to burn. Plastic items that become detached from the interior cabinet and wind up laying on the defrost heater which gets very hot during defrost is another, however, I would demand a service call (free) since everything on it is under warranty. Make sure it's creating the odor when the tech shows up.
Posted on Oct 30, 2009
6ya staff
SOURCE:
Kenmore 253 refrigerator/freezer won't stop running on any setting. The food in the top of the refrigerator would freeze unless I partially blocked the vent. I am wondering what the problem could be. i...
I have a Kenmore model 253 freezer/refridgerator upright model. I am getting cold spots in the refridgeration in and near the vegetable drawers on the bottom of the refridgerator. The icemaker works but the water dispensor has stopped working too.
Nov 28, 2010 | Refrigerators
Odor eminating from freezer
Dead mouse or rat is a definite possibility.
May 04, 2017 | Haier RRTG18PABB (207 cu ft) Refrigerator
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator with bottom freezer. freezer works,refrig does not. Can you help me find the problem .Also, bar between the upper doors gets real hot.
I had this problem. The Evaporator fan in the freezer was working but no air would be circulated from the freezer into the refridgerator. To test this you open the door of the freezer, and depress the door button(s) of the upper refridgerator doors so that the light extinqueshes in the refridgerator. This will engage the evaporator fan in the freezer. You can check to see if air is venting from the freezer into the refridgerator by feeling the holes at the top most part of the multi-air flow channel in the refridgerator. If air is comming out when the freezer door is open, close the freezer door and feel if air has stopped. If you have kept the upper door buttons pushed in on the refridgerator and now have the freezer door closed, you should still hear the fan running, but may have not air flow with the freezer door closed. The cause of this is the air return channel from the refridgerator to the freezer is either frozen or clogged. My return-air channel was not frozen but clogged by a residue from something that spilled inside of the bottom of the refridgerator. The return-air channel has two vents in the rear-bottom of the refridgerator that exit into the freezer behind the evaporator (cooling coils). You can't see it even if the back interior panel is removed from the freezer compartment.
The bottom line here is that if air is prevented from moving from the refridgerator, back down to the freezer, then your refridgerator will not cool, but your freezer will work just fine. You will not need to replace the fan, unless the fan is not functioning. You may need to check the dampener, to ensure that your multi-air flow channel is open - (allowing air to come into the refridgerator). The multi-air flow channel is easy to remove once all of the shelves are removed from your refridgerator. Only 2 screws holding it in (securing the center rack top and bottom). The top screw is located behind a small plastic cover that can be removed.
That's what worked for me.
Jan 12, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Foul burning odor
you could possible be right on if your frig has an electronic disp control put your nose their and sniff if seem close to what you earlier smelled you solved your problem pcb control '
Aug 20, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
Foul dead animal smell from kenmoore side by side refrigerator/ice maker
I'm sorry that I don't have a solution, but we have the exact same problem with an older model KitchenAid side-by-side. Did you get this problem solved? If so, can you share what you did?
May 27, 2009 | Kenmore 50522 / 50524 Side by Side...
Foul odor coming from freezer. Kenmore model w/ freezer on top.
Clean the refrigerator thoroughly fresh food and freezer under all drawers. Then place charcoal briquettes in each 8 or 10 total. 4 or 5 in the bottom of the fresh food section. leave the for several days. If that doesnt take away the smell consider if a mouse may have gotten into a fan blade and well that can create a really bad smell.
Jan 10, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Maytag MFD2561HE Bottom Freezer French Door Refrigerator Logo
272 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
