"Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
You need to disconnect the USB cable and set it up wireless on both units:
Since it is plugged into the router, it should already have an IP address. Un-install the printer from the computers.
Then re-install the printer from the cd or from HP's website. When you get to the point where it ask you is the printer is attached to the computer or is it over the network. Choose over the net work and the software will find the printer IP and finish setting it up wireless.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
You can connect the printer to the laptop through a USB connector. Make sure to plug the printer into an external power source as well. (into the wall basically). If the printer did not come with a usb cable, you can buy one from newegg.com or tigerdirect.com
