Go to www.searspartsdirect.com. Put in your model number, you read from under the seat, and it will give you a parts list and diagrams you are looking for this mower.
Hth
Good Day.
Look up under the foot boards on the tractor, Sears usually puts the diagram of the routing for both belts under there.
If you can not locate those stickers, look in your Owner's Manual, the parts section will have a picture of what the belt looks like when it is installed.
If you don't have the owners manual or simply don't know where you put it, look under the seat, get the Model number for the tractor that begins with 917. then go to searspartsdirect.com enter the full model number and download the parts manual and in most cases you can also download an Owners Manual as well.
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
SOURCE: need a diagram for a sears craftsman 42 inch deck drive belt and
I don't have a deck diagram but you should be able to figure it out it you put the back part of the belt (flat) up against the pulleys that are wide and the narrow part (v) into the smaller pulleys. It might take a couple of times but it is not that hard to figure out. Also put the (flat) side of the belt on any tension idlers. Hope this works.
