Question about Sony KDS-R60XBR1 60" Projection HDTV
I TOOK IN MY KDS-R60XBR2 TELEVISION. I WAS GETTING NO PICTURE BUT I WAS GETTING SOUND. I WAS GETTING 4 RED FLASHES. (SONY RECOMMENDED ME A MOM AND POP STORE THAT DO REPAIR.) THE REPAIRMAN SAID I NEEDED A NEW FAN (DON'T KNOW WHICH ONE)ANYWAY, I GET THE TV BACK AND 4 MONTHS LATER....I CAN HEAR THE FAN. IT'S VERY ANNOYING AND LOUD. I CALLED THE REPAIRMAN AND TOLD HIM ABOUT THE PROBLEM, AGAIN HE SAYS BRING IN TV AND IT COULD BE ANOTHER FAN GOING BAD. HOW MANY FANS ARE THERE? TV IS 2 YRS OLD? WHAT'S GOING ON? THANKS.
  • 587 Answers
Hi my name is Roety,
I can help you with your issue ,
 There are 3 fans, but the main one is the one that usually goes bad location 103 here , The fans only cost about $20 each and are easy to change.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Oct 27, 2009
6ya staff
SOURCE:
KDS-R60XBR2 No picture, no sound but solid green light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 21, 2014 | Sony Kds-r60xbr2 60" Xbr Rear Projection...
Power error 6 times - 11V is low. - No picture/No sound
From my past experience, yes. Not sure about the 11v being low. My kdf 45 acted that way when the main lamp went out. Found a replacement on Amazon for around $45 and now good to go! So far about a year and a half. Have had to replace about 4 for friends and family so far with same symptoms. All worked great! http://www.amazon.com/F93087600-Projection-Replacement-KDS-R50XBR1-KDS-R60XBR1/dp/B005I4OLAS/ref=sr_1_13?ie=UTF8&qid=1386773721&sr=8-13&keywords=Sony+Sony+Kds-r60xbr2+bulb&tag=donations09-20
Dec 11, 2013 | Sony Kds-r60xbr2 60" Xbr Rear Projection...
No picture or sound
Which light or lights on the set's front are either on or blinking, red will usually blink a error code, if blinking look for the number of red blinks and a pause
Dec 13, 2012 | Sony KDS-R60XBR2 Television
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
Aug 04, 2012 | Sony KDS-R60XBR2 Television
KDS-R60XBR2 projection 60'' Sony tv the picture is turning yellow why is this happening
It sems that you are having a problem with you color wheel, that is what makes the variation of color happen in your tv set, if that is not working correctly, it causes either a black and white picture, some times no picture at all or like in your case to much of one color.
Jul 20, 2010 | Sony KDS-R60XBR2 Television
TV will not turn on. Red light flashes 4 times
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Mar 07, 2010 | Sony KDS-R60XBR2 Television
I have a sony tv model (KDS-R60XBR2)That is flashing 5 red on the front panel. No picture no sound,I have tried reset through remote (display-5-Volume plus)still no screen . Any ideas?Thanks Ron
I had the same problem last year and when I contacted the Sony repairman he looked it up and said it was the fan. He said the red light blinks 5 times to signal the fan is blown.(According to their booklet). He came and replaced the fan and it was as good as new. Good luck!
Jan 02, 2009 | Sony KDS-R60XBR2 Television
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
Sony KDS-R60XBR1 60" Projection HDTV Logo
424 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
