did you just change your oil? there should be a drain plug on the bottom to drain the oil. they don't normally come loose but if you just changed or had someone do it for you it is possible that it has come loose and fallen out. be sure the dipstick is in the hole. i hope this helps
If your model does in fact have markings on it or in the manual indicating it is a 4-cycle tiller you need to put straight gas in the gas tank. It will also have an oil plug/dipstick on the motor that you have to check to make sure it is full of oil. The oil should be checked every time you fill the gas tank for the safety of your motor.
the Honda FG100 is a 4-cycle engine do NOT mix oil with the gas, - you will cause damage to the engine (head, valves, piston rings etc) not to mention if will not run well.
