The simple and most expensive solution is to replace the ice maker assembly. They sell for between 50 bux on e-bay to 150 bucks at Sears. From what I have seen most ice makers fit the same category and they look like they are all designed and built by the same company!!
The main problem is the gear on the backside of the unit snaps off for various reasons like ice cubes getting stuck and causing the ejector rake to jam, thus overloading the flimsy gear and snapping it off. You can not purchase the gear however you can choose to buy a gear-head assembly for 80 or so bux.
http://www.appliancepartspros.com/part_details.aspx?part_id=3177342&pn_=8201515
shows a typical repair kit. Just enter your model number on their website to find the exact match for your ice maker.
I repaired the broken gear on mine using some structural epoxy. Here is a pic of the repair in progress, The green stuff in the center of the gear is the epoxy I used. Good Luck!!
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
