Is the water coming from the water dispenser on the door or from inside the freezer ? if from the water on the door, there is no drain..if the water continues to drip from there, you have a "air leak" in the line somewhere. If the water comes from the freezer, there is always a drain line and hole there, sometimes it is behind a panel, but it is there usually covered with ice if it's dripping out onto your floor. You need to let that ice thaw and I use a small hose (6' long) that will fit in that drain hole,get it at a hardware store.. fill the hose with water and push or plaace it into that drain hole..blow that water into the drain hole so it will wash out what might be in there causing the blockage. This amount of water will go down into a catch pan (already there) and evaporate. Restart your refer and watch for it in a week or two if it's back, do it again or check the drain tube on the bottom back, for any kinks.
