Toro Lawn Mower With Toro Power Tools Logo
Anonymous Posted on Oct 23, 2009
Toro Lawn Mower Electric Start Won't Engage
I have a Toro Model 20018 Electric Start Lawn Mower. When I try to start it with the Electric Start, it just makes a ''whirring'' sound, and doesn't seem to engage the motor... (probably doesn't engage the flywheel is the correct term)
The battery is fully charged, and it starts with the Pull Cord ok, but I want to be able to use the Electric Start.
Any suggestions as to what could be causing this?
Thanks,
Jim
Anonymous
Level 2:
Champion:
  • Expert 205 Answers
  • Posted on Oct 23, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
205
Questions
Helped
121671
Points
484
You'll need to pull the starter. It sound like your Bendick's is bad. that's the upper gear drive assay. the only other res ion would be, low power to the starter, and not receiving an acquit amount of amp to reach the rpm's it needs. good luck
Testimonial: "Thank you for the advice.... I will check out the Bendix to see if that is the problem. Jim"
  • Anonymous Feb 02, 2012
    I have the Toro 20070 and having the same problem. I removed all the removable parts on the starter; cleaned, inspected and found out that the "Gear" can rise up and down on the "Armature" to engage the fly wheel. I will move the "Gear" to the flywheel, turn the key and the engine will start; however, the "Gear" goes back up over the flywheel than I will get that grinding sound again.
    I believed a part is bad, but I do not know which one. I have the part list and diagram.
    Can anyone help me with this problem.
  • Anonymous Jun 05, 2012
    Well Harlan or BigD...Was that the solution? How did it turn out for you?
Toro electric starter will not engage
Starter bushing is bad....
Sep 10, 2012 • Toro Garden
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Have a Toro Personal Pace 190 cc electric start mower. About 18 months old. Battery can be fully charged but it only seems to start it about every third or fourth time. Pulling the cord starts it every...
battery or cable problems
When using the battery , there is insufficient power left to run the ignition system
when pull starting what is in the battery is sufficient to start the engine
I have a Toro 22"
Odds are the battery needs replaced. If it is a 12V battery, you could try jump starting to test the starter to verify. If it is a 6V battery you will have to find another one to jump. You could check the battery with a multimeter to check voltage if you have one or know of someone who does. Make sure you know how to do this properly so as not to destroy the meter. The meters can be cheap or expensive, depends on the model and the features, but always bad idea to let out the magic smoke.
I hope this helps.
I have a Toro 20" self propelled, electric start
I am strictly Briggs&Stratton. They are hard to start when the fuel tank is half empty. Clean the plug and air filter.
6helpful
2answers
Toro Personal Pace Mower won't start w/ electric starter
There are a couple of things you can check;
First, check to make sure the bendix is engaging. It is the gear that meshes with the fly wheel.
If it is, then try and see how fast the motor is spinning. Don't look at the blade though. It could be a faulty starter motor.
Make sure to also check the battery voltage with a volt meter. It should read at 12.0 or higher.
1helpful
I have a Toro electric start 22'' inch lawmnower Model No. 20018 with a Tecumseh LEV 90-120 engine. The mower may be started with the electric start or manually with the cord. The battery was in need of...
It sounds like the starter drive may be jammed. It should not be engaged unless you are using the starter motor. Take the spark plug wire off, put on heavy leather gloves, and try turning the blade by hand to dislodge the starter drive. If it does dislodge, plug the spark plug wire back up and try the pull start again.
Hey thanks. My Mom's Toro 20018 lawn mower has
Should have had it taken care of while still under warranty.
You have carb issues. In google they will tell you how to adjust various makes of carbs after you clean them out or get a new one.
Jun 23, 2017 • Garden
3answers
Toro mower dies when i try to pull out
Disassemble carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Make sure that the small screen is free of debris. Reassemble and start.
If this doesn't work, then you will need to buy a carb. kit and replace all the appropriate parts.
Jim
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
