Maytag top load neptune washer error code od
I own a maytag neptune, top load washer with electronic board or lcd screen, od code display, those are the door switches locates on the side of the door, the switches are electronic, an after opening the washer an opening the switches I discovered that the wire that sends the signal from the switches to the board were broken an rotted from the mold an soap that got accumulated in the switch, I took the switch an cleaned all the electric contacts, an stripped the wire back to were the wire was in good shape an re-solder the wire back to the switch, assembled back together an had the error went away ( no need to do anything else), the switches are attach to the machine with a 1/4 in screws , if you are not handy with soldering wires, you can order the part, ask for the lid switch give them your model number an I think they run about 75 dollars each, time to change em if ur a newbie, maybe an hour , I can do it in maybe 20 mins tops!
try it hope it works for you!,,,,,,
new washer 600
new parts 150
making a wife happy...............priceless!
good luck! let me know.
