Kenmore 44832 Front Load Washer Logo
Posted on Oct 22, 2009
Kenmore washer 417 44252500 does not spin. Goes thru wash cycle and rinse. Replaced control board.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1327
Points
Replaice door swith
Kenmore 600 series triple action technology repeats cycle
check if the sensors are working effectively. In addition, you can check . You can plug and unplug the washer from the power it may help
I have a Kenmore top load, high efficiency, low water washer. How to get to rinse and spin ?
May be a bad door switch. Washers usually let you open the machine (top load) while in wash, but not for rinse and spin because of the high speed. If the door switch is bad, it may think the door is always open and therefore wont go past the wash cycle.
Kenmore Front Load Washer won't complete cycle F06
Have you cleaned your machine lately? They make an in wash boost- it gets rid of the extra suds built up inside the machine that you cant see but your machine detects it and causes faults such as that. Also, there is a small wire on the control board that may need replaced if it keeps kicking the error code.
2helpful
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
I have a Kenmore stackable washer/dryer (apartment size) and the washer will shut off when it goes into the spin or rinse cycle. If I turn the control knob to rinse or spin, nothing happens. The washer...
try looking at your pump or you need a cupler that goes on the back sid of the motor price range for the pump is 120 dollars and the cupler is 35 dollars dont quote me on the price of the parts please but that should fix the problem.
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
15helpful
3answers
90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Kenmore heavy duty series washer
you need a new timer. order part thru sears.
Front load washer wont spin
yes. the solinoid or wax motor (depending on which switch you have) has fail and is not telling control that the door is locked. replacing the switch will fix it
Alexander
vince
