Apple iPhone 3G Logo
Posted on Aug 17, 2017
Iphone 8mb 3g showing usb cable and itunes logo.
I have a jailbroken iphone 3g 8mb and it is showing a usb cable and itunes.i cant do nothing but enter a emergency keypad. i tried to connect to itunes but it wont let me in that either, its saying to insert correct sim (on itunes). i HAVE a good signal and i'm receiving messages and incoming calls so the sim is working fine. its just i cant make calls or use any of the phone . please help
5 Related Answers
Anonymous
  • 679 Answers
  • Posted on Feb 20, 2009
SOURCE: Iphone doesnt detect in Itunes and Usb wall charger doesnt work.
It sounds like the unlocking screwed up part of the software, if you are using the newest version, there is a problem when unlocking the phone. If you down grade to the prior software version, it may fix the problem, it's difficult to know what people have done to the phones due to the many different methods of unlocking jailbreaking etc, if it were mine I would try to do re install of the prior firmware, if that doesen't work, you may be able to just get a new sim card from your provider. That is more than likely what got messed up
Anonymous
  • 53 Answers
  • Posted on Mar 07, 2009
SOURCE: iphone only see apple logo and itunes logo in a dark screen after
If it got wet, you can bring it to any Apple Store. Nine times out of ten they will replace it for $150 to $200 dollars. Unless they determine it is a manufacturers defect and you are still under warranty, then you want have to pay anything. they will usually just replace it for you.
Otherwise, you may have to pay up to $200 for a replacement.
Hope this helps...Let me know...
enov8
Anonymous
  • Posted on Jul 12, 2009
SOURCE: iphone is disabled but do not have original sim card to activate
my iphone wont respond to touch and is frozen on the screen with the usbpicture and itunes, also its not detecting sim.
Chris Sorrows
  • 136 Answers
  • Posted on Aug 11, 2009
SOURCE: Hi I have an iphone 3g that I unlocked and
Your phone has been relocked. It will need to be hacked again.
CaptDP
  • 133 Answers
SOURCE: iphone 3g stuck in emergency calls only
Are you using at&t. if not it was jailbroken and unlocked and that went away after you updated it.
My iphone has an itune and a usb picture on the interface
That means you should connect it to computer and restore it with itunes. But if you're jailbroken or using Unlock, don't do this!
3answers
Iphone 3g stuck sn0wbreeze logo
Try t o see if you are using the latest snowbreeze version which is compatible with iphone 3G.I will recommend you ti use WhitedOOr firmware for iphone 3G,as it is much faster to use.
Iphone will not turn on! Shows Apple logo then fades out?
Leave the phone plugged into the car charger with the "plug into itunes" screen long enough to build a charge. It sounds like the phone is dying before it gets a chance to connect to itunes and start charging through the computer. If this does not work then the store clerk was correct and your battery will need replacing
Iphone stuck on itunes screen with usb
First power off your iphone and restart it does it start normally or not.
Secondly restart your iphone without connecting to computer. so remove usb cable and restart your iphone ipod or ipad. Even though iphone stuck all logo and itunes and usb symbol then it is a issue of original sim
Secondly when you connect iphone to computer and it detected as recovery mode then your ipod iphone is not properly restored. Here is how to restore ipod / iphone or ipad.
1helpful
I just cleared my iphone. It wont boot to the screen where it says to connect to itunes. it starts up with the apple logo, then shows that rotateing thing over the apple logo, then it stops rotateing, and...
To resolve this issue, you will need to restore your iPhone to factory settings This means any data (music, movies, contacts, etc.) will be erased and the iPhone brought back to it's factory settings (like the day you got it).
To do this, follow the steps below:
1. Make sure your iPhone is disconnected and powered off. If it's not already, hold down the power button until the "Slide to Power Off" message is displayed and swipe to turn off.
2. Connect the USB end of the data cable to your computer, do not connect the other end just yet.
3. Connect the other end of the data cable to the iPhone and immediately press down & hold the "Home" button.
4. Continue to hold down "Home" button , until the iTunes logo appears and the USB connection is displayed on the iPhone's screen.
5. Open iTunes (if it hasn't opened automatically) and a message stating that it has found an iPhone that is in recovery mode. (If you don't get this message and the iPhone just boots like normal, then the timing between connecting the iPhone and holding the home button wasn't fast enough. Try again from step #1).
6. Click the "Restore" button and iTunes will automatically download and install the latest iOS version for your iPhone.
The process should take about 20-45 mins, depending on your internet connection. Once complete, the iPhone will reboot and will be restored to factory settings.
Since iTunes requires that all data be synced through there, if you have made any backups to your iPhone, you'll be able to re-sync your information back to your iPhone at this time.
2helpful
2answers
Dl an app and now it trys to boot but cant
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.
23helpful
3answers
Frozen jailbroken iphone 3g
I'll recommend you re-break your phone and if you are willing to perform the task in a more simple yet time-saving manner, follow the step by step guide from this website: iphoneunlockeasily.com
5answers
I have a jailbroken , 3g iphone . i wanted to delete some things that i could only do by going to reset data and settings , so i did that , and now when i power on my iphone it only shows the apple logo...
Alternative Method:
Step 1. Connect iphone to USB then listen to the sound when it connect and disconnect.
Step 2. Hold the home and power buttons until hear the disconnect sound then release power button.
Step 3. Wait until you hear another sound then release home button.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
