Both top sections fridge/freezer of my side by side are not cooling, but the bottom sections are cold. The lower fridge drawers are freezing the fruits and vegies while the top shelves are warm, also the ice in the ice maker melted while the lower section kept the food frozen. The top vents have low air volume.
Go to youtube and you can find alot of DIY videos and ohm testing of the thermistors, defrost thermastat, defrost heater. If you can use a volt ohm meter you can fix your refridgerator
Here is a youtube link on GE refridgerator cooling problemshttp://www.youtube.com/results?search_qu...
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.
Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
