This dishwasher has worked very well for about 6 months but now leaves a heavy film on everything (e.g., glass, plastic, flatware). I've watched it through a complete cycle and it appears that everything is working (i.e., fills, drains, water is hot, etc.). We haven't changed anything that would have to do with the dishwasher's operation (i.e., same Electrasol detergent, the rinse receptacle is full). I read on the net to throw some vinegar in at the rinse cycle which helped remove the several cycles of film but left the dishes smelling of vinegar. I've called GE and they will send a technician but I'd really like to know what this problem may be before this person shows up.
Go to www.dishwasherfilter.com and your glasses will BE PERFECTLY CLEAR AND SPOT FREE!!!
Also, when ordering use promo code DF5150 for a discount!
As far as using the vinegar, this should be complete when there is NOTHING in the dishwasher. The idea is to remove the build up inside, not clean the dishes. Make sure to use only White Vinegar. Also, changes in the water of any kind can cause a build-up. Try using a little less detergeant and rinse.
In this case there is no way to reduce the amount. Check the water supply for calsium. This will build up under the screen and turn the water foggy thus leaving a coating on dishes. To check, look at one of your glasses. It it has a light milky look then I would suspect calsium. Do you have a water softer/filter ? If you do, check this unit also.
Calcium is usually found in water treatment plants. It is added as a healthy by-product. This would have to be filtered out at the home. There are several filter/softener manufactures on the market.
The scum, film and white
residue problems have started since the reduction of
phosphates in dishwasher detergents.
Here is a tip that
will help you to solve the problem of films, residue, and scum in
your dishwasher.
Dishwasher
Residue and Film on Dishes
heatman101
Here is a tip that
your dishwasher.
Dishwasher
heatman101
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Thanks for the info on the vinegar. How do you use less detergent when it comes in those pre-measured cubes (with the rinse ball)?
Thanks for the info on the vinegar. How do you use less detergent when it comes in a pre-mixed cube (with rinse ball)?
how do I get rid of the calcium?
