Windows xp home.
x3470 all in one printer.
downloaded all new files from website.
also tried using the manufacturers disc.
both have resulted in being unable to install the printer drivers.
scanner/copier/ all ok.
UNABLE TO INSTALL PRINTER
removed every software trace 3 times, and started again - no good.
installed on correct printer port, tried turning off anti virus/firewall and setup again, again no go.
what can i do ????
might add, all windows updates etc are all current.
nothing glaring obvious.
One of the most possible reason is related to Print Spooler service. Please check the "Print Spooler" service if its turned on. if its not you can turn it on. Here is the way to go Services screen
Try reinstall
Good Luck
Try reinstall
Good Luck
Try reinstall
Good Luck
this is not a issue, as the print spooler s automatic and already in operation.
Perhaps i explained it badly, but the "error message" states "printer driver not installed.
ie.
2 messages grey boxed , with red x, and "duuuh sound"
state : lxcypswx.exe - Bad Image
and
lxcycfg.dll
more than once have tried deleting these files via reg edit, and then renstallling after every lexmark removal, no joy.
Have tried to use Control Panel/Add Printer etc. Nope.
Have tried to use Computer/Device Manager/update drivers. nope.
I cannot get the pc to add this as a printer, thugh it lists Symantec Fax and lexmark Fax.
any other ideas ???
its not buying !!!!
OK UPDATE TIME.
I DELETED EVERYTHING RELATED TO LEXMARK from the registry, restarted 2 or 3 times, and actually read the manual.
re downloaded the latest software verion from website, and followed my previous commented actions.
It is now installed and works.
Thankyou for all responses.
Flap
i am having the same issues have you fixed and how. It says I need lxcycfg.dll
noting is working, same issue as first
