Garden Logo
Posted on Oct 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mcculloch M13597 i have a Mcculloch M13597 lawn tractor that wont start nothing happens when i turn the key have changed the battery and still nothing
mickey813
Level 3:
  • Master 472 Answers
  • Posted on Oct 19, 2009
mickey813
Master
Level 3:
Answers
472
Questions
0
Helped
215303
Points
1078
CK THE FUSES SOUNDS LIKE ITS NOT GETING POWER TO THE SWICTH
1helpful
Nothing happens when I turn the key
If you havemade sure the battery and conections are good check for a fuse for the start circut or lights most tractors have a switch under the seat that killsv the engine start circut check thisvand make sure that it is not your problem yuose a volt meterv or test light to check power to all the battery connectios
Toro/Wheelhorse Tractor wont start
AS YOU HAVE CHANGED ALL OF THESE COMPONENTS TO NO AVAIL IT HAS TO BE A BREAK IN THE WIREING ITSELF, YOU WILL HAVE TO FOLLOW THE WIREING WITH A MULTI METER TO FIND WHERE THE POWER IS LOST.
May 02, 2012 • Echo Garden
2helpful
19.5 hp twin craftsman serial number 917259560 turn key nothing happens battery new, switch uner seat in ok position
Check that the blades are not engaged. If they are not engaged and you still have nothing, check battery cables tight. Then check the starting solinoid.
If you have any questions on how to do this or other related, just reply.
Craftsman 54 in lawn tractor W/ 26 hp Kohler engine
Could be, but test each item with your tester. Test key switch (12V in and 12 V out when turned to start., operator present switch 12V in 12V out (seat) Clutch switch, etc. till finally you test for 12V on the small terminal on the starter solonoid. Happy testing!
5helpful
2answers
Nothing happens when you turn on the lawn mower key for craftsman mower model 917 272072. I put a new battery in the mower, and new switch and a new solenoid switch but the mower don't make any noise when...
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
I have a 20 h.p. craftman lawn tractor model 917288130. The engine will not turn over. I have changed the battery, and all I get is "clicking" when I turn the key.
you can try an lightly tap the starter with a hammer to see if it's stuck,....while holding key to start,....this happens on mine sometimes,.....not to much you can do,..kind of poorly built these days,.....good luck, cracklin joe
I have a mcculloch M13597 lawn tractor that wont start , nothing happens when the key is turned have changed the battrey and still nothing
Jumper across the 2 terminals on the starter solenoid with a pair of needle nose pliers and see if the starter spins. If so then you have a bad solenoid or a safety switch activated or maybe a bad key switch Hope this helps you
Oct 19, 2009 • Garden
2helpful
Craftsman 15.5 lawn tractor (917.271061) won't start
Here is a link to the manual wiring schematics on page 31
Please rate this a fixya
1helpful
2140 cub wont turn over when trying to start
Change the solenoid, if you can jump the posts on the solenoid and the engine turns over...the solenoid is bad
2helpful
Mtdb 115 lawn tractor will not start
Make sure the handle that lowers the blades is pulled right up into the last slot,and it is in neutral.
Trev.
Apr 01, 2009 • Garden
Top Briggs & Stratton Garden Experts
Jay Finke
Jay Finke
john h
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
