Nautica Men's Eclipse Chronograph Watch for Men,Model #N18507G - Need insruction to set time and date
Hello
i have hour nautica ... number A29506.. i wants to change date ... please tell me how to chenge .. maybe you write in my e-mail
[email protected]
tthenks..
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
SOURCE: need instructions to reset sub dials on Nautica Chronograph watch
Pull out crown to the first click and push and hold pushbutton at 2 or at 4.
SOURCE: to adjust time on a watch
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
SOURCE: how to change the date on cartier santos chronograph watch
There are two positions for the setting crown all the way out is to set time,one click out to set date.To set the date you must first set the time by moving the hands around clockwise until you see the date change(midnight) then continue around to the correct time.Then push crown in on click and set the date
SOURCE: Date setting on Citizen 0510 chronograph
Try this method. Set the date until it reads a couple of days in the past and then set the correct time. Of course do not touch your date or time settings between the hours of 9PM-1AM. Wait until the next day, then move the hour hand forward until you reach the current date with the correct time.
