SOURCE: 1990 Model Subaru Legacy 2.2
It's for yr rear diff.Theres a lever just behind the hand break.You need to push it forward which will sort this.Good look
SOURCE: how to check manual transmission oil level on 1999 camry 220gl
There is a check plug on the side of the transmission, fluid level should be th the bottom of the fill hole, here's a picture.
SOURCE: transmission fluid level check 02 jetta tdi auto
VW didn't put a "dipstick" on the trans for whatever reason. You technically have to use the VW Vag-Com scanner to properly check the trans fluid level as VW says it has to be checked at a specific temperature. But there is a "shade-tree" workaround. Start the car and leave the engine running the throughout the entire procedure. You have to get the trans fluid warm-a little under normal operating temp. 95F-104F is what you want-you can attain this after letting the car idle for 8 or so minutes. Continuing, leave the trans in park, and make sure you are on as level of a surface as possible. Then loosen the allen plug on the bottom of the trans pan. You will then see another plug. Remove this plug. Fluid should just trickle out of the hole if it is at the proper level. If it trickles out, you are good. If it doesn't you need to add fluid. Add VW spec ATF through the fill port.The fill port on the top front of the trans is capped off by a red cap and is very visible. Very carefully pry the cap off and then wiggle the plug out. I'd highly suggest having a spare red cap on hand-VW dealer has them. Then you can pour fluid into the trans. Add a little bit at at time, and all the while watching for the fluid to tricke out of the trans plug hole. When it trickles out, replace the inner plug and then the outer plug. That's it. Recheck after driving the car for a few miles. FYI- A flud and filter swap on the the VW auto trans takes 3 liters, so keep that in perspective. I hope this helps you out.
SOURCE: check engine light has come on
You need a code scanner hooked up to it to find out why the light is on.
If there is an advanced auto or an autozone near you, go there and tell them the engine light is on, and you need a code retrieved. They don't charge for this, where other places do. Tales about a minute.
SOURCE: checking gearbox oil level on 92 Suzuki Swift manual
'92 Swift - LH side of diff housing, rearwards of the LH drive shaft. Has to be filled to this plug's level.
brand is yardworks ... no model or serial number
need brand and modle number and ser number
Joe, I think you talking about the level of Hyd fluid. I would just make sure the level is above the intake line to the pump.Also if fluid level is low you would not have full travel of the ram.You would also hear the pump cavitation.Hope this helps
