My Computer's Microphone (Headset) is not working with Windows Vista. But It is working with Windows Xp.
So Please give me the solution. Give me settings so I can start it
My microphone has always worked on vista for, I use it everyday on skype, but today it will not work, I can hear the caller but they cannot hear me. I thought my headset was broken and i bought a new one. but its still doing the same thing with the new headset. It says the microphone settings are enabled and working, but when i do the mic test, it says that it cannot hear me.
what can i do?? help!
I had that problem and I think I can help.
-Type in Sound in the vista search or do the control panel Hardware and
Sound thing to get to the sound stuff. Hit the Recording tab. If you
have the same problem as I had, you will see Stereo Mix and Microphone
there, but Stereo Mix is the default and Microphone says "Not working."
What you need to do is click on microphone to select it, and go to the
bottom of that same tab and hit set default. Sorry I'm not too
technical, but for me this solved the problem.
I am using Windows Vista Laptop & I have got accidentally removed the Realtak Audio Input recording device (i.e.-MIC),hence I am not able make a voice calls on internet like skype ,googletalk etc.
Can anybody tell me how to get Installed my MIC(recoeding device) back to the PC.
In Control Panel->Sounds & Devices->Audio->
Sound Recording Default Device ( Audio Input Device)is showing empty.
I want To know What should I do to get back my Audio Input Device so that I can use my MIC of HEadset to used for talking on Internet.
Raja
My microfone not working with windows vista i need solution
Just got off with Dell support. Make sure both headset plugs (microphone & headset icons) are plugged into the 2 headset jacks. Do not plug the microphone plug into the microphone port when using a headset. Use both headset ports. This was the problem for me.
Microsoft Vista SP2 could be the problem - Soundmax driver no longer working for the mic. Windows update installed High Definition Audio Device for a driver - mic still not working. My dual boot (Vista, XP pro) to XP still works fine. Driver problem with Soundmax and Microsoft.
Finally after few months
of problem i managed to get my mic running in vista. First get the new drivers
from net it will say version something compatibility issues when u try to
update it. Then uninstall the driver from the pc from device manager,
select sound video game controller… and then your sound card or onboard
which ever company. Select and right click uninstall and then the check box
delete the driver for this device. Restart you pc and when it starts to update
the driver in the task bar cancel it. And go to the device manager same sound
video… this time it will say high definition audio, select it and update
driver, browse my computer, select LET ME PICK FROM A LIST OF DEVICES, next
have disk and give the location of the new drivers that u have downloaded if it
does not take them then try the i386 folder in it. Will prompt u drivers not ….blaa
blaa yes and pronto did work for me hope it does for u. And yes I have asus
board with soundmax drivers got them from
http://download477.mediafire.com/8yuuj4inln2g/2dytwwoznmm/%5Bwikidrivers.com%5D+Analog_Device_SoundMAX_6.10.02.6585.exe.
Best of all use driver
genius pro, it will tell u what latest driver u should have. If it can get the
drivers for u fine otherwise get the from net and follow the rest. Mail me for
any other explanation [email protected]
Sharad Gandhi.
I have tried all of the solutions above-
* Reinstalled Vista
* Checked jacks are properly connected
* I do not have ANY other software installed on Vista
* Disabled and enabled Sigmatel
* Checked other versions of mics
* Checked sound settings in control panel
YET my mic is not working. The speakers and headphones are working fine.
I am using Dell Inspiron 6400. The mic is external with a headset.
HELP!!!
I rolled back my sound driver, after that it worked perfect.
read this. Might help alot Vista users with Mic issue:
http://www.miguelcarrasco.net/miguelcarr...
I have in built microphone on camera in USB port & it cannot hear me. GDMALL 1370, video working fine on Vista, looked at Device Manager, Sound & chosen mic says it's working & set as default but still not picking up my voice. Nothing is muted & no on & off switch on set. it is plug in USB & should work but doesn't....any ideas anyone???
What kind of microphone are you using. If you're using a Carbon Mike (that's like the kind included in a lot of Software Packages), they're already high gain (some case too high). Look a the setting for microphone, you can increase gain by 10db, that will get you there with one (over gain).
If it's not a Carbon Mike, that's so common, you required a pre-amp for the microphone, I'm using a Equalizer that has a gain of up to 12db, and it work fine. It's FET, so it also isolates, so I'm using another on for Line Out. Work's great, and I can balance it.
HELP PLEASE....
Im so dumbed with this problem, my new headset is not working in my vista starter! i try a lot of remedies in the net but still no such solution! my recording device always state this gray in color "microphone high definition audio device not plug in"..
someone help me please ..
any comments is highly appreciate! thank you..
I just reinstalled windows vista due to a bug.. now I cant talk to my friends with my microphone or use my head phones to listen. I can hear everyone talking to me thru speakers but not headphones. HELP!
*********** board driver supported in windows vista?, if not support downlod sound driver files for "6285_Vista_APO_PG536.zip" and installed.
SOURCE: asus p5rd1-vm vista internet.
you may of answered your own question, there is a bios update utility here
SOURCE: vista audio problem
Here:
http://dlsvr01.asus.com/pub/ASUS/misc/audio/ad1986/AD1986A_Vista32&64.zip
SOURCE: I need the Asus P5VD2-MX SE drivers for Windows 7
You can try the link provided below. As you might all ready know, Asus does not provide drivers for windows 7 and your MB, P5VD2-MX SE.
http://driver-pro.com/related/english/windows-7-drivers/?a=17743&gclid=CJLvoozNs54CFYRC5god1UbDdA&hit=1&l=45
Cheers!
Mike
Post your findings at [email protected]
I have Head set and microphoe is with headset and working fine with windowxp but not working with vista. so this answer is not proper and there is not settings is given which is required
Thank you
Bhavesh Dave
Dear Sir /Madam
I have Headset of TECH-COM SSD-HP-203. SoundMax drivers are not supporting. I think Drivers is not available that reason it is not working. So Gide me from Where I can get driver for the Sound card
i m using vista and my built in microphone doesnt work with vista..it was working well with XP
my computer dont hear my mic on window vista but worked fine on window xp
is there compatability between Skype and Vista ?
i had problem with my computer that use window vista about microphone that didn't work properly but in window xp it work normal and the sound when i spoke so loud to out and in window vista not loud. what should i do? can tell me to this problem?
i am using a headset not usb and it wont let the mic work and its new and i am guessing its not brokin
i had problem with my computer that use window vista about microphonethat didn't work properly but in window xp it work normal and the soundwhen i spoke so loud to out and in window vista not loud. what should ido? can tell me to this problem?
mahin
my microfone is not working with windows vista i need solution.
I have Head set and microphoe is working fine with windowxp but not working with vista. so this answer is not proper and there is not settings is given which is required
