Your tractor was manufactured by AYP (American Lawn Products). They make ALL of Sears tractors. (The #917 prefix is the giveaway - Murry would have been #502). They also make the tractors for Poulan, Roper, Sears, Rally, Wizard, Woodwards, Yard Master, Kgro, Rally and several others. My tractor is also a AYP and all Sears tractor parts will work on my Ranch King.
You can find any AYP part you need at Outdoor Distributors.
http://outdoordistributors.com/AYP/AYP_Main.html
If you don't have your original a owners manual with parts breakdown, you can download one here:
http://www.hammerwall.com/Manuals/Craftsman/Description/917.273130/Craftsman%20Lawn%20Tractor%2017.0%20HP%2042%20in.%20Mower%20Electric%20Start%206%20Speed/L0301175/
(Parts breakdown starts on page 31).
I suggest that you go to http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=917.254860+ and find your part there.
Hope this helps you.
Go to a small engine repair shop for your part.
Sears tractors are just other tractors (Mostly Murray brand )with the sears name on them......as are most others.
There are only 2 or 3 manufacturers making all the tractors.
Your part should be easily ordered there with your model and serial #.
Sears carries or will procure parts for nearly all Craftsman products and has illustrated parts breakdowns for thousands of them.
Go to the link below and enter your machine's model # to see
if yours is one of those they cover:
If you find it, it will have a line-drawing illustration that can aid in determining how to access the different parts.
Ok I dont have part number because they dont have schematic.It is the part after the electric clutch think there called tension pullys they are used when changing deck belt for mower.(two pullys,with spring and arm for releasing tension when changing belt)
So take whole assemble to repair place that works on Murray tractors?
What is the part that you need?
