Wire shelf in freezer of Frigidaire refrgerator - has holes that appear to be for adjusting height of shelf. How do I move - wire shelf is jammed in tight?
Since on differnet models it goes right or left,
but you should be able to push the shelf one way, enough so that the other side pops out of the wall
then slide in the long side first, you will see what i mean when you have the shelf out
push the long side in with a lil pressure and raise the shelf the leve you want it installed on
On mine, there was a plastic clip, ~5/8" long on the left side of the shelf that prevented the shelf from being moved far enough in that direction. Removing this clip allowed me to remove the shelf.
Thanks, my worked exactly as you said.
How did you get the clip off? I've been trying to remove it, even with pliers it won't budge.
I was having the same problem, the shelf just wouldn't come out no matter how hard I pushed or pulled on it. Then I noticed a black rubber, semicircular, 1 in. wide band attached to the left front rung of the shelf that was keeping it from bending, some kind of a safety device. Once I took it off, the shelf was easy to remove and place in the holes above, and I replaced the piece of rubber afterward.
