The Kenmore Oasis and Whirlpool Cabrio washers are essentially the same. Following is the Whirlpool Installation and service manual for their Cabrio washers.
The DL indicates a problem with the door lock mechanism. See the section on troubleshooting and display codes.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Testimonial: "this is great information. thanks"
SOURCE: dl error message
This is a door lock error. Unplug the washer and inspect the lock and latch. If all appears well, check the wiring connections to the switch, and where thay connect to the brains. Also check that the lock and latch are tight. Tighten any loose fittings and connections. Usually the lock is at fault, but it can be the brain.
Best regards, --W/D--
SOURCE: F11 and/or dl code on a whirlpool duet front load washer
F11 is:
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check for:
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Check the above link for a detailed article about the f11 error code.
Courtesy:JSrock
SOURCE: mod110.28072800 580oasis washer
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
