I have a 19 inch but the directv remote will not work with it? I called directv and tried all the codes they have to make it work but they do not have a code for a polaroid
Here are some remote control codes that have worked to control Polaroid HDTVs:
My 19" w/DVD uses the following Mitsubishi code: 10178
Dish Network remotes: 627, 659, or 688
DirecTV RC64 remote control revealed a code of 10835. This means that 10835, 0835, 835 or some variant many work with many programmable remote controls. On my DirecTV DVR system, this was indicated as a Moxell and/or Motorola TV code.
Use the mitsubshi tv codes they worked for me.
Try Element codes if they are listed in your remote code list.
I installed systems for Directv, and whenever i went into a home that had a combo tv / vcr, i could never get a set to program properly. At the most on some sets the remote would turn the tv set on and off, but others functions were non responsive.
Best bet is to call the TV manufacturer and ask them if they have any codes that might work. Often off brand televisions are produced by a major manufacturer and may respond to standard codes not mentioned in the manual.
i have a silvania 19 inch tv i went to att tv and cant make there remont work cant find the proper code have to use tv remont and atts remont to run the tv
Orion code is 11911 and to program your tv to work with a directv remote then follow these...
Setup Instructions
Set the "Mode Switch" to TV.
Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
Enter the 5 digit Code above.
Slide the "Mode Switch" back to Directv and try adjusting volume and turning tv and receiver off using the off button and then back on with the on button just above the off button
