Washing Machines Logo
Posted on Dec 26, 2007
Kenmore HE3T - 11042932200 leaks from front of machine
Hi -
My Kenmore HE3T - 11042932200 leaks from front of machine. The door seal is still good and the locking mechanism functions. The leak comes out of one of the seams in the fromnt of the machine. It looks like the white metal is leaking water that is being diverted from somewhere in the machine. Please help.
  • Anonymous Dec 31, 2008
    I have the same problem. Water is leaking at the lower front of the machine. Looking underneath the machine I can see the drips coming between the sheet metal seam. I will take off kick panel and look further, but if someone knows the root casue of this please let me know.
richfes
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Nov 19, 2008
richfes
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
Questions
Helped
423
Points
Had similar issue. water leaking from between front panel and kick panel (curved joint). took front and top off washer. only water trail was small puddle below left shock mount (looking in) to tub front.and water pooled in the shock mount. only thing i could find wrong was the multi-ring seal between the dispenser and despenser tube to the bellow. it was crudded up and had some excess rubber lumps. i trimmed the excess and cleaned the seal and tubes and put it all back together. so far no leaks. left the kick panel off to allow inspection through a few loads.
A
Anonymous
Boot tear in front replace
1helpful
Elite HE3t washer, in the middle of a load, it stopped. it flashes dL, F
door lock error...door lock mechanism broken,,,replace door switch,,,if your lock out remove toe panel and reach up and pull tab,,always unplug first...good luck
How old is this washer? he3t 11042932200
The date of manufacture is determined by the SERIAL number. The following link explains:
http://www.fixya.com/support/r2880489-determining_age_whirlpool_appliance
The first two numbers in the serial number identify the WEEK it was manufactured. The last digit before the number sequence identifies the YEAR.
Take a look at the link provided and let me know if you still have questions. I hope this helps.
NOTE: Kenmore washers are manufactured by Whirlpool, so these instructions will apply to your Kenmore.
2answers
Kenmore Elite HE3t Front Load Washer leak from dispenser
I was just about to call the service teck when I decided I shouldn't be this stupid and try and fix it myself.
I took the tray out and looked in with a flashlight.
Saw nothing.
Cleaned the tray and then checked the drainage hole inside the opening where the tray normally feeds the machine the soap.
I found a inside of the liquid XXXKing laundry cap partially blocking the drain.
Took it out and works fine.
1helpful
He3t washer leaking corner bottom
You will need to remove the lower kick panel directly below the door to gain access to the inside cabinet to see where the leak may be coming from. The panel comes off by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off.
NOTE: Propping the two front feet of the washer up with something (a 2x4 works well for this) will give you better access to the screws.
The most common source of leakage on this washer is the rubber bellow around the door. It can develop cracks or tears over time and require replacement. A tell-tale sign is the front counterweight (looks like a concrete block on the front of the wash tub) looking wet. The counterweight will remain dry if the tub is sealed properly. From the inside of the washer, pull the rubber folds back on the door bellow and inspect the perimeter for any rips or tears. If the bellow is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If the bellow is intact, check the rear bellow seal where it connects to the front of the wash tub. If the clamp comes loose the bellow can shift and begin to leak. Tighten if necessary.
Check the drain pump and hoses to ensure they are not leaking. The drain pump is directly in the front under the wash tub.
Check the area directly below the wash tub. If the leak is coming from the wash tub iteself, you may have a bad tub seal. A replacement gasket doesn't cost much at all, but the labor involved is extensive.
Another simple problem is the dispenser tube(s) that come through the door bellow. Sometimes, these small tubes will work their way behind the rubber in the door and leak when the washer attempts to fill or rinse. This is a simple matter of adjusting the tubes to ensure they are seated through the door gasket properly.
If you have any questions, or require additional assistance, please let me know. I hope you find this information helpful.
NOTE: You can refer to searspartsdirect.com for some excellent exploded view diagrams of your washer for reference in locating components.
8helpful
2answers
Kenmore Elite HE3 water is leaking out the front door
These are notorious for the door boot leaking. Look for any tears, rips, pinholes in the door boot. Also make sure the door is parallel with the machine. Most likely it's the boot. Parts about 100.00. Labor can run from 110-140 depending where you go.
1helpful
Kenmore Elite HE3t door leaking (Model 44936)??
If the unit leaks during use with a constant drip from the 6 o'clock location between the seal and the glass on the door the solution is to change tha door seal. it is quite difficult to do I would recommend you call a local service company.
Door seal
Hello melmendorf
Welcome to fixya.
I'm Huuum and happy to assist you,
You asked, how hard is it to replace a Kenmore HE3T door seal?
If you have not done this job before you may not want to do it!
I've had people asking me why it is still leaking after they ryed to save a couple buckd and do sef service.
Please remember to leave a rating before you go!
Thank you,
Huuum
A kenmore HE3t front loader MO. 11042932200
Suggestion: Plug off the wall first. Check to see if all the connections are firmly pushed in; during the job some could hv come loose. Check the wall outlet, your washer plug....whatever. Then plug in.
1helpful
Leaking....front door won't close
Carefully look at the door gasket to see if any irregularity in seal. Could be problem with door seal; or you could easily change door mechanism thru a spare part shop quoting your model and spare-part No or "door mechanism"
Kenmore Elite HE3t Front Loading Washer
Try holding 'end of cycle' button for 3 seconds. If not........
  • Door Lock Mechanism broken or removed from the door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
If you get the door to open try some WD40 on the door mechanism, not on door, and open/close a few times. "Plug should be off the wall" when trying this, and tinkering inside machine, caution.
Alexander
vince
