To verify whether the problem is with your cd drive or with your sims 2 disk, try running a different disk in the drive. If you are successful in opening and running the other disk, then your cd drive is fine and your sims 2 disk is faulty. If you've had the sims 2 disk for a while, it may be scratched.
If the other disk shows the same symptoms, I would suspect that your cd drive is bad and needs to be replaced.
