Question about Refrigerators
Frigidaire Model # GLRS267dzw2 ice maker isn't filling up with water too make ice.
  • Refrigerators Master
  • 1,606 Answers
As every technician knows , a water and ice dispensor refrig , has a dual water inlet valve . Just because the water dispensor works , does not mean the coil for the ice maker is working . Pour about 2/3 cup of water into the ice maker . If it dumps the frozen cubes , but does not refil with water , check the fill tube inside the freezer , from the wall to the fill cup on the ice maker , to see if it is frozen . If so , replace the dual water inlet valve , due to seeping . This is not closing completely , and letting drips thru , which freeze inside the tube . If the tube is not frozen , then the water inlet valve is bad , not letting water thru to the ice maker .
If the ice maker does not dump the frozen cubes , then the ice maker needs to be replaced . Also check the coils under the refrig , to be sure they are clean of dust , lint , etc , as this will raise the temp above 5 degrees , which is the operating temp , for an icemaker .
Posted on Oct 12, 2009
  • 30 Answers
You may have fault water inlet valve or ice in the tube.
If you are able to get drinking water from the dispenser, then water inlet valve is good. If not, that is a problem. Replace the valve.
Posted on Oct 11, 2009
6ya staff
SOURCE:
My Frigidaire side-by-side refrigirator is not making ice
Here is a simple tip that may help you decide what is causing this problem. If the ice maker has no ice cubes in the slots fill with tap water and allow water to freeze. If the ice maker cycles and drops the ice into the ice bin and then does not refill with water the problem is the 241734302 Water Inlet Valve (providing that the model number above your post is correct) If the ice maker only sits there with ice in the slots and does nothing the ice maker is the problem 5303918277 Ice Maker Assembly Testing the water control valve is as follows. I will be here to answer any questions you may have, Thanks Sea Breeze
Apr 26, 2013 | Frigidaire FRS26H5AS Side by Side...
There isnt any water getting thru to the icemaker. i changed the watervalve and still no water i cannot locate the water filter even tho i removed the bottom grill, water is still getting to the water...
if you put a new water valve on the fridge then you either have a bad ice maker or the line is frozen where the water fills the ice maker,a bad water valve will make the line freeze,water keeps dripping through the valve and freezes the fill line behind the ice maker cup,you can remove the ice maker and check the fill line,if it's frozen get a hair dryer,shut down the fridge or unplug it and blow the hot air into the fill line until the ice melts,then get a piece of wire and after you reinstall the ice maker pop off the cover to the ice maker and jump it out with the wire,stick it in the t and h for 15 seconds and pull it out,if the ice maker is good it will start turning and when the arms get at like 11 oclock it should fill,also you can jump out the fill valve from the ice maker,stick it in v and L and if water fills the ice maker you know you have a bad ice maker if the fill line isn't frozen.hope this helps.next time you need help send the model number,on your machine look in the fridge section on the right hand wall up near the ceiling to find it,if it's older look down near the bottom hinge on the fridge door and you'll see a tag with the model number.good luck
Sep 12, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Frigidaire side by side refrigerator, model # FRS26LH5DQ5. When the ice maker fills with water, water also comes out of the water dispenser on the front of the left door. What is causing the...
HI, TO ME LOOK THAT YOUR REFRIGERATO HAS A BAD ICE MAKER, BUT IF YOU REFRIGE IS OVER 5YEARS OLD REPLACED THE ICE MAKER AND SELENOIDE WATER VALVE ,100%PROBLEM REPAIR..
Feb 21, 2011 | Frigidaire Side by Side Refrigerator 26...
Frigidaire glrs267dzw2 side-by-side mfg 11/2004 - ice maker does not sense when bin is full, continues to produce ice (and a mess). My only recourse is to turn ice maker off.
Looks to me your model had the older style ice maker that uses micro-switches to tell what is next in the six parts of one complete cycle. Some times those switch's stick on or off and tend to break. Here is a link to an exploded view=> 5303918344 Ice Maker Exploded View
Let me know if you have any questions so I may help you better, Thanks, Sea Breeze
You can try to disassemble and repair, just be aware that the lever spring will be the hardest part to understand putting back in if you by chance pull the facing off it can jump out of its location giving you hours of fun trying to return to its proper place. The ice maker replacement part is=> Click on photo or 5303918344sea_breeze_71.jpg
Feb 10, 2011 | Frigidaire Refrigerators
Frigidaire refrigerator model PLRS2672ABB6 - Ice maker not working - just replaced the valve in the back and it seems that the water is not going in the line up to the ice maker
The valve is replaced.But still water is not flowing.Check the water flow is the water flow running.If yes then the other possibility is ice got frosted build up in the water fill tube.Use hair dryer to defrost that ice collected in the water fill tube.Check this both possibilities,1) The water flow and 2) The ice build up in the water fill tube.--------------Thank you.
Jan 25, 2011 | Refrigerators
Currently the water is leaking from the ice maker. there is ice build up in the control box its self, and its leaking from there. No sure how the water is getting in tot he control box itself so i'm...
You are right - it is filling up with too much water. If you remove the front panel of ice maker you will find a screw there that adjusts the length of time that the solenoid stays open to admit water. Turn it counter clockwise to reduce the time and amount of water entering the ice maker.
If you need new maker get them cheap on ebay. eBayeBay
Sep 08, 2017 | Frigidaire FRS23H7CS Side by Side...
Frigidaire refrigerator, ice maker
If the ice maker is doing the normal cycle and when calls for water doesn't get any,probably the fill tube to the ice maker is clogh with ice because the dual valve (solenoid) is leaking and this water freezes up clogging the fill tube , or the solenoid doesn't work ,in both cases it has to be replaced(it's located in the back of the refrigerator attached to the water supply line).
Aug 28, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker not working - Frigidiare refridgerator Model number FRS26BH6CB4
take the line off of the solinoid valve and check to see if there's a screen in the valve. that could be plugged with debris.
Dec 20, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Refrigerators Logo
466 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
