Cooktops Logo
Posted on Oct 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display on clock fade out but if i cover it for a few min it come back up mod. jenair cook top sve87600b
Fix Your Board
Level 3:
Guru:
  • Master 310 Answers
  • Posted on Oct 10, 2009
 Fix Your Board
Master
Level 3:
Guru:
Answers
310
Questions
0
Helped
124293
Points
1016
I've often seen the display on these units go dim due to a failure in the control board. It may well start out as an intermittent failure. Your comment about covering it reminds me that some ovens have an ambient light sensor to automatically dim the display but I don't recall seeing that on your model.
In either case, it sounds like the classic failure mode we often see.
If you can have the control removed, we may be able to help you, we repair oven controllers at www.fixyourboard.com.
Best Regards,
Bruce
Why is stove top displaying symbols not recognizing pots? Had stove 6 weeks, pots are correct and been used on this stove. Displaying on all 3 cooking areas.Can I correct it or is it faulty?
lets review this
please advise readers
maker of cook top so they can find the user manual
model or how old helps also
its not a gas cook top
you have the right type of designed pots for that cook top
but you get no heat radiating to the pot base
when pot is in contact with the heat area
Aug 17, 2016 • Cooktops
tip
Proper Use and Care of Ceramic Glass Cooktops
Here's some helpful tips that can hopefully ensure many years of quality use of your ceramic glass cook-top.
NOTE: It is important to maintain PROPER care of your ceramic glass cook top as they can be very expensive to replace. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most manufacturer warranties DO NOT cover cosmetics. That is, if your cook-top paint starts to wear off from normal use, or from the selection of cookware you choose to use, manufacturers typically WILL NOT replace it. Warranties also DO NOT cover accidents such as dropping something on the top and chipping or breaking it. Some warranties WILL cover, however, blistering, warping and heat related breakage that were no fault of the consumer (as long as you were using the recommended cookware). It is important to become familiar with, and follow, all the manufacturer's use and care instructions that come with your range.
CERAMIC GLASS CHARACTERISTICS:
It is normal for the ceramic glass to change color when heated. This is especially true for lighter colored surfaces. The color should return to normal when cooled. It is also normal for the enameled or painted areas on the cook top to show signs of wear and fade over time. Proper cleaning and cookware selection can extend the cook top appearance.
It is NORMAL for the radiant heat surface elements to glow red and cycle on and off. There is a thermostat associated with each individual element that regulates the temperature. The frequency at which the elements cycle on and off is determined by the heat setting.
PROPER COOKWARE:
Use ONLY flat bottomed cookware for the best results of heat transfer from the surface elements. Cookware with warped, rounded or ribbed bottoms can cause uneven heat transfer which can result in uneven heating of the cooking surface and cause damage to the cook-top such as cracking and/or permanent surface discoloration.
An easy test you can use to determine the flatness of your cookware, is to turn the cookware upside down and place a ruler across the surface. As you rotate the ruler around the surface perimeter, you should not see any light along the ruler edge where it meets the surface. Cookware with slight indentions or expansion grooves can still be used, however.
Make sure the cookware bottom is always clean and dry before use to prevent any foreign matter from burning to the cook-top surface and leaving stains. ALWAYS place your cookware on the cook-top surface BEFORE turning the surface elements on.
Make sure the selected cookware matches the size surface element in use. The cookware surface should NOT exceed one inch beyond the radiant surface element surface.
COOKWARE CHARACTERISTICS:
The material of the cookware you select will determine how well it transfers heat and how evenly it cooks. The ideal cookware should be of medium to heavy thickness.
NOTE: A non-stick surface will take on the characteristics on the base metal used. (i.e., non-stick over aluminum, will take on the heating characteristics of aluminum).
*ALUMINUM - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*COPPER - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*Both aluminum and copper are great when used as a core metal cover with a non-stick or enamel surface. However, when used as a base metal, alone, they can leave metal transfer marks on the cook-top surface which will have to be cleaned immediately following use.
GLASS or CERAMIC - Heats slowly and unevenly, may scratch cook-top surface if there are any rough edges, best results are when using low or medium heat settings.
CAST IRON - Heats slowly and evenly, maintains heat for slow cooking, great for browning and frying, rough on cook-top surfaces, may scratch.
STAINLESS STEEL - Heats quickly and unevenly, a base or core of aluminum or copper can provide more even heating.
DO's and DON''T's:
DO NOT store heavy items, such as jars, cans, pots and pans above the cook-top surface. Any inadvertent dropping on the cook-top surface and cause cracks or shattering.
DO NOT lay hot lids on the cook-top surface. Heated air can become trapped under the lid creating a hot spot as the rest of the cook-top surface cools. The cook-top surface could potentially crack when the lid is removed.
DO NOT slide cookware across the cook-top surface. LIFT cookware as much as possible when moving from surface to surface. This will minimize metal transfer marks and scratching.
DO NOT cook popcorn in prepackaged aluminum containers. The aluminum could potentially melt and may not be able to be removed from the cook-top surface.
DO NOT store anything on the cook-top surface that could melt (such as plastic and aluminum foil). Once melted to the surface, some of these substances may not be able to be removed.
DO NOT store empty pots and pans on the cook-top surface.
DO NOT attempt to use the cook-top surface while the oven is on a self-cleaning cycle. The oven super heats to temperatures in excess of 500 degrees and causes radiant heat to be exhausted from the oven vent on the stove surface.
DO NOT use a cook-top that is cracked. Any spill overs could potentially leak into the radiant heat elements and create an electrical hazard.
DO clean up any spills from the cook-top surface that contains milk or sugar. You may allow the cook-top surface to cool in order to safely clean, but do not allow these substances to remain on the cook-top for extended periods. If not removed, these substances can cause permanent discoloration and stains.
DO wipe down the cook-top prior to, and immediately following use, to maintain the surface appearance.
DO NOT attempt to cook any foods directly on the cook-top surface without a pan!
CLEANING and CARE:
Clean all spills and boil overs immediately.
Any substances that become adhered to cook-top surface can be removed by wiping up excess with hot soapy water and a kitchen sponge.
Use a non-abrasive pad (the green kitchen pads are considered non-abrasive) and a straight edge razor blade, pushing in one direction to remove stubborn particles.
Some metal transfer marks (copper and aluminum) may be removed by simply wiping cook-top surface with a damp sponge. Any remaining marks can often be removed with an approved cook-top cleaner.
Use only approved, non-abrasive cook top cleaner to keep the surface clean and polished.
DO NOT use scouring pads that will dull or damage cook top surface (i.e., steel wool or SOS pads).
DO NOT use any harsh chemicals such as ammonia or bleach that can etch or dull cook-top surface.
on Apr 19, 2011 • Cooktops
1helpful
Instruction manual for baumatic cook top
Hi Darren,
Whats the model of your cook top?Here's the manual for a few Baumatic cook top models.
Hope this helps.Thanks!
Please rate this answer.
1helpful
Jenn- Air cook top oven sve47500b has error # F7 and the oven will not work
F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
How do you remove the cook top on a GE profile model number JSP47SOH2SS
take off the knobs, unscrew the plastic underneath the knobs, take off the plastic cover. unscrew the four metal screws holding the the display panel on. remove the 5 silver screws across the top inside of the plastic cover front and the 2 black ones on the lower left and right sides. remove the to stainless steal stews on the sides of the stove towards the rear top. these should allow you to remove the cover once you unplug the two cables going into the burners.
Feb 26, 2010 • GE Cooktops
3helpful
The jenair made a popping sound, wasn't even turned on. Then found it didn't work at all. Flipped the breaker, and it would immediately flip back, the Jenair would also make the same popping sound.... Do...
I had the same problem. Mine was caused by liquid seeping into the infinite switch (the switch that gets rotated by the knob to set burner temperature). This caused one of the live wires to short to ground within the switch. Bad Design IMHO. Replacing the switch fixed the problem (you can get replacement parts at Searspartsdirect.com - search using the cooktop model number).
You first need to remove the unit from its installation. Start by disconnecting the exhaust fan from the ductwork. Then push the cooktop up.
To get at the switch you need to remove the top by taking off only the top row of screws all around the unit and also in the down draft cavity (the down draft cavity is where the grease guard mesh is)
1helpful
My GE Profile gas cook top was just cleaned. Now the starter keeps clicking and the only way we can stop it is to unplug the appliance. As soon as we plug it back in it continues to click.
if you have a multi meter you can figure this out. check to see if you have continuity through the switches while they are in the off position and unplugged from the spark mod. if you do replace the wire harness. if you dont replace the spark mod.
Dec 05, 2008 • Cooktops
Cook top
Sounds like you have cartridge fuses in your house. When only one is blown it can cause interesting results. The clock is probably feeding back through the burner. This lets enough electricity through to run the clock and othe small things but not enough for heat. Have all the cartridge in your house tested. I'll bet either one of the mains or range ones are bad.
2answers
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Top Jenn-Air Cooktops Experts
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
