SOURCE: RCA Model F36450 Chassis ATC113CA1 won't power up
No sir it probably isent a power supply problem as in these sets it wouldnt act like that. First thingm to check since you say your a service tech, is in the horizontal output check and see if the horiz. output transistors shorted. If its not then check a small coil off the base of the horizontal output transistor. its really the base drive coil so take it out and scrap off the ends BOTH ENDS and reinsert and also resolder the horizontal driver transformer. This may or may not fix your problem But if it dosent order if you think ther sets wrth it the flyback transformer as this is a big problem in these sets if the for mentioned things did do the trick. follow the kit instructions that come with the flyback transformer!! Dont take any short cuts. Make sure you do take out the horizontal output transitor or at least unsolder all the leads when tesating it for a short. Good luck
SOURCE: f32650/atc113ca1
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
SOURCE: RCA 32V524T- Blown fuse?
If you blew the fuse, the TV would do absolutely nothing - no lights, no sounds, nothing. It could be that the loud zapping noise you heard was the high voltage transformer arcing or shorting out. This could have caused the horizontal output transistor to short, and the set will not start as a result. You should have the set serviced by a qualified tech.
SOURCE: 52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
SOURCE: RCA color tv,model 27F520T,Chassis M134C
On the tv panel push and hold volume down until volume is all the way down and keep holding, then push the info button on the remote.
