Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
Anonymous Posted on Oct 06, 2009
My Kenmore Elite freezer door came off one of its hinges. I cannot figure out how to put it back on so that it stays. The connection has an upper hook with a lower hinged arm. It is strange.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6562
Points
I just spent the better part of an hour on this. There is a white flange with two phillips screws. If you take this off it is easier to see the mechanism, but you may be able to get it back on without removing the flange. I removed the flange. The mechanism attached to the door has a hook facing up and a smaller hook facing down. There is a hinged metal bar below this. The bar has a hinged piece with a loop on it. Pull the loop up. Now push down on the piece with the hooks ( it has a spring) and hook the smaller hook on the loop. Do this for both sides. Now the door should slide easily into the slots. Once in the slots, push down on the hook piece and release the loop. Push the loop back in place along the bar. Hopefully this does the trick for you, it did for me.
  • Kingkta Dec 04, 2011
    Thanks for the info. Like you, I spent a good part of an hour trying to figure it out all the while watching my items in my freezer defrost. Until I came across your post. Your description of what to do was spot on and I fixed the problem in a matter of seconds! Thanks again!
  • Charissa Hogan
    Charissa Hogan Mar 20, 2016
    I am having this same issue and get it to re-hook for anything. Any other tips?
Mitzi Downey
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Posted on Jan 12, 2022
Mitzi Downey
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
Questions
0
Helped
6562
Points
Https://youtu.be/jI4IoIWqSFg
heres a video showing how the two metal pieces hook together. It's hard. You really have to put out and almost use two hands.
Jimbo
Level 1:
Welcome Back:
  • Posted on Oct 03, 2020
Jimbo
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
6562
Points
This takes some acrobatics with the spring loaded hook. First, on The smaller hook, push the locking clip flush with the hook. Then draw both hooks together before you insert into the door. I dismounted my door from the track so that I could manipulate the spring loaded hook out from the door, while guiding the smaller clip in underneath - when you get the right angle, it will slip into the slot below the slot the larger hook goes into above. This may look impossible until you push the spring loaded hook down and pull the top out a bit. Watch your fingers. Once it seats, then you can pull the hinge fully open, push back the plastic molding, and open the little locking piece, which had to be closed flush with the hook when you started. This thing is ridiculous, but it can be fixed. I’m sure it can be done with the door mounted, but I’d rather not torque on all that plastic and slide rails. Just two screws allows you to dismount the door frame from the track. Do it.
Anonymous
Level 2:
  • Expert 60 Answers
  • Posted on Oct 06, 2009
Anonymous
Expert
Level 2:
Answers
60
Questions
Helped
20711
Points
144
It is strange that the door came off. If it did not brake.. laying the refrigerator on it's side,or getting a friend to help hold the weight while you secure it should work.
  • Geoffrey Duncan
    Geoffrey Duncan Apr 25, 2014
    OMG! Thank you so much. I was jacking with this for over and hour and about to throw this thing out on the curb when I found your site. Your instructions were spot on. I fixed it in 2 minutes. WOW! Thank you so much!!!!!!
Bottom freezer door will not stay closed.
Check the hinges and the door seal. If you need parts Sears service center online has a great parts locator for kenmore
Kenmore Elite Oasis Washer Mod #110.27082601 Ser # CT1170582. I went to put the lid down and heard a "pop" type sound, and now the lid won't stay up. Everything else is working properly, and the...
Hello Chrissym1313,
Taken straight from the APPLIANCEPARTSPROS.COM
website... (Left & Right hinge Springs)
Hi--the lid on my Kenmore elite washer does not stay open on its own anymore--from what I have read-sounds like I need new hinge lid springs--can you tell me part #'s and how I would go about replacing those--thnx!!
Mike J for Model Number 110.28082700
Answer Hello Mike. You will need to order WP8580114 and WP8580115 for the unit.
Cross Reference Information
Part Number WP8580115 (AP6013571) replaces 8563961, 8580115, PS11746797, B008DK65SA, B002M647S6, B072YYQ2TQ.
Right hinge spring:
http://www.appliancepartspros.com/whirlpool-hinge-spring-rgt-wp8580115-ap6013571.html
Left hinge spring:
Whirlpool WP8580114 Hinge Left AppliancePartsPros com
Hope this helps
Carnac the Magnificent
Once you have your absolute part numbers... Then you can go SHOPPING... (Left: on eBay $25.50 plus tax & shipping)
New OEM Whirlpool Kenmore Washer Door Hinge 8580114 WP8580114 LH eBay
Right hinge
Amazon com Kenmore Elite W8580115 Washer Lid Hinge Home Improvement
RH hinge on PARTSELECT... ($39.20 plus tax & shipping)
Whirlpool WP8580115 Hinge PartSelect
11helpful
2answers
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
2helpful
On my Kenmore Elite Bottom Freezer Refrigerator, the display on the left door reads ErCo and the ice maker does not work . Its less than 2 years old
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
Wiring in door has been cut: What does it do
In the freezer it would be everything in the freezer door. Water dispenser, ice dispenser and any light associated with the dispenser.
Freezer door not sealing
replace the seals and / or have the hinge adjusted
2helpful
Sears trio elite ...french doors with bottom freezer...right side loose on freezer door handle...thanks
I have the same refrig. After taking the freezer basket hinges off, thinking I had to take the whole door a part to access the screws for the handle...my husband figured that the handle probably slides off...and yes that is just what it does!
Push the handle in a bit and then slide to the right. It takes a little bit of effort but that handle will come right off. Then you can tighten the screw that holds the clip in place. Then you line the handle back up to the clips, and slide to the left. Good Luck!
Freezer Door Fell Off
Generally, door hinges have a post on the door part and a hole in the box part.
In fairness to Sears, you caused the problem.  Ice is caused by failure to keep the door closed, open containers with damp product inside and the like.  Forcing the doors will cause them the distort and that's what you did.
You may have to pay a visit to Sears and look at a floor model to see what it looks like.  Take a camera.
Elite trio
Hello bigmikeegator
Welcome!
You said, you have the Kenmore Elite Trio Bottom Freezer. You moved your refrigerator to a new home and removed the bottom freezer door, but can not seem to figure out exactly how to put it back on correctly.
It's too much for me to tell you myself.
This is easier!
Page 9 shows you how to remove and reinstall doors.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523115.pdf
Thank you,
Huuum,
Please remember to leave a rating!
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
