Check the water pressure or any filters in the water line or a crimp in the supply tube. Also make sure you totally defrost where the water enters the ice maker.
the problem is the line is freezing up due to obstruction or blockage. which causes the water to back up and freeze, I have used a blow dryer, hot water, and a soft type long tiny tube or cord like material and even a coat hanger but be very careful, to get inside the line and unplug the obstruction or if u can remove the whole line and replace it? but may be very difficult. why was it pluged? some times pc's of plastic bags, old food particles, etc get into the line, doesnt take much
If the light and ice dispenser on the front panel works and If your fridge is 4 years old or older, the insulation in the freezer door has most likely deteriorated and the water in the tube feeding the water dispenser has probably frozen. Open the freezer door, put a blanket over the food to keep it from defrosting, and use a blow dryer to defrost the door. Blow the hot air on the flat panel inside the door (the backside of the water dispenser). Close the door about every 5 minutes to check to see if the water works. Once the water begins to flow, you have successfully defrosted the ice in the tube. Defrosting the door works for about 12 hours until it freezes again. To solve this problem, I placed a 10" weedeater line up thorugh the dispenser nozzle leaving about 1/8 of an inch sticking out. When the line freezes again, pull out the weedeater line, dispense water to free the ice, and then reinsert the weadeater line. I keep the line in all the time...it works great! If the light or ice dispenser do not work, the problem may be *********** board.
It sounds like there is a leak and the insulation in the door is wet. If it is real cold on the outside then that is a positive indication the insulation has failed for some reason. Good Luck, Gilshultz
The water line runs through the door and this is where it freezes. It's usually defetive insulation. Other than replace the door you may can tape or other wise fasten more insulation to the inside of the door in the area you think it's freezing in.
it seems to me that the tubing is not properly insulated in the door causing it to freeze you can open the liner and see if it is inside the insulation or lower your freezer section so it does not over freeze thanks from gilles
I found that the door on the GE side by side doors are not accessable and cannot be repaired if a water line inside the door is defective. The entire door must be replaced at a cost of almost $370. The problem, which seems to be quite common relative to the lack of water at the dispenser, is the result of the water tube in the door freezing due to excess cold levels in the freezing compartment. This is probabley due to poor insulation around the water line as in exits near the ice dispenser gate. The solution is simple, lower the freezing level and use water frequently to keep it from freezing. Also, keep the lines clean by changing the filter often if the local water source is laden with particulates. I think GE should foot the bill for changing doors or re-engineer the doors to access the area where the water line makes contact with the cold surface of the inside panal.
You may have a problem with a frozen water line inside the freezer door. There is a heating element that keeps that water line from freezing but it apparently has failed. It is not serviceable. The whole door has to be replaced.
At bottom hinge of freezer is the water line to door. Undo connection in line. It may be a quick connect. To undo push in on one end flange to release, and pull out line. Put bowl under end from under refrigerator and make sure doors are closed. Now push water dispenser and see if water comes out line. If it does, the line is frozen in the door. They had some models that had air leaks in freezer door. This causes insulation to freeze and water line freezes. Push in on inside of freezer door and see if it sounds like snow crunching. If it does it's probably frozen. Also peel door seal back a bit and see if is held on by numerous screws. If it is, it may be one of them that freezes. Call GE. They may still have the program going where you get 2 new doors free. Give them your model and serial numbers.
