Refrigerators Logo
Posted on Oct 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I switch the handle from the left to the right side? I have model ARB9059CS
Anonymous
Level 3:
President:
  • Master 1,304 Answers
  • Posted on Oct 06, 2009
Anonymous
Master
Level 3:
President:
Answers
1304
Questions
0
Helped
367217
Points
3700
Yes but you will need the left handed hinge that came with the unit
Anonymous
Level 2:
  • Expert 308 Answers
  • Posted on Oct 05, 2009
Anonymous
Expert
Level 2:
Answers
308
Questions
Helped
152298
Points
748
No this model does not have a reversable door option.
May Tag Referigerator
The MBR1952KES Has the hinges on the right only, you need to order a custom made door to move hinges on the left.
Here is picture
3answers
Where is the reverse switch on my black & decker 1/4 7004 drill type 1
The now vintage B&D model 7004 type 1 was a single-speed, non-reversible drill. There is no reverse switch.
2helpful
I have an old Guardian Power floor model drill press and do not know how to change belt positions to change speed. help please.
See the picture below. The small red circle shows the locking screw on the right side of the drill. There is another locking screw on the left side of the drill. Loosen them both a half turn. The larger red oval is the handle to pull the motor closer to the spindle, thereby loosening the belt. Once loosened, it is easy to move the belt. Then use the handle to push the motor back, which tightens the belt. Keep pushing on that handle with your right hand while you tighten the locking screw on the left side of the drill with your left hand. Once you have that tight then tighten the right side locking screw.
Good luck! I hope this helps.
Jul 12, 2012 • Drills
Encore Premier 36 walk behind- safety switch connection problem
you can adjust the handle not the switch try and swapping the switch with the other side and see if the problem follows the switch
May 12, 2012 • Garden
Switching door sides
some model you can, some you can't....if there are pre drilled holes with plastic plugs on the opposite side you can....you will need to purchase hinges and maybe handles.
2answers
Left hand retrieve
Unscrew handle put on other side .
3helpful
Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
How to reverse door on kelvinator fridge?
Im unable to look up htat particular model number for you, looks like my FRT18, which is made by the electrolux company, in which case, YES you can easily switch the door swing form one side to the ohter, whats on the left goes to teh righ and right to the left, not a problem
1helpful
Right door handle upside down pinches fingers. how to remove and flip?
mirellis, grab the handle with both hands and push in and up. The handle will slide off the retainer clips. To put them back on, line up the clip holes push in and pull down. I never tried flipping them, but you will find out real fast. This is for the GS6NBEXRL model that was posted, Catriver.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
