If your dryer came with a regular grounded cord attached, it is a gas dryer, and you will have to hook up a gas line to the 3/8 pipe nipple at the lower left corner (when viewed from behind). The 4 prong power cord is only used for electric only models. If still unsure, post the model number from the sticker inside the door of the dryer.
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
