Garden Logo
Posted on Oct 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
46 in yardman model OEM-190-112 I need to know the belt pattern please
Anonymous
Level 3:
  • Master 389 Answers
  • Posted on Oct 04, 2009
Anonymous
Master
Level 3:
Answers
389
Questions
0
Helped
273399
Points
1274
If you get the correct model AND serial number off the tag under the seat, go to mtdproducts.com and you can download an owners as well as a parts manual for your tractor. One or both of them should have your diagram and routing for the belt
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 • Garden
How to change a Yardman M.T.d. transmission drive belt diagram on 46" cut?
You can go to the Yardman website and download the service/owner's manual.
Aug 18, 2014 • Garden
I just changed the drive belt on my 2007 mtd yardman and now I have very little speed any suggestions to the problem
If the belt is correct you may have wrapped the belt around a "belt keeper" that you didn't see and the belt is dragging on the keeper ,or the belt is not correct,or it was not installed in it's correct path.
Blade route
I can't give you an answer on this without knowing the model number of your mower.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Need to know what size and hoe to change belt for yardman 46" cutting deck for blade model # 13a0771h055
If you are missing the manual, for the said model,
I have found that the simplest way, of figuring out the correct route for the belt, is to remove the deck, and hold the replacement belt above the mechanism, with the tension from the engine end.
Then 'mock up' the replacing proceedure, bearing in mind the correct direction the tensioner/s, move in.
Then it's not too difficult to figure it out the correct route.
Hope that's clear enough, good luck.
3helpful
Yard man mtd 20hp 46"cut hydrostatic drive lawn tractor,model"13AU69H401 deck belt need diagram to put it back on?
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
