The machine now only makes a few ice cubes before freezing up and cannot cut and drop ice
Do you mean frosting up? If so then check the seal around the door. Check to see if the control is set too cold. You may need to make it warmer.it should be between 10 - 15 degrees in the bucket. It could be too cold or it could be too warm.
First do a good cleaning as the manual describe.
check water supply and if still the problem, check power to cutter grid
should be 9 volts all the time
