Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Anonymous Posted on Dec 20, 2007
Stand by mode
When i turn on my tv it flashes stand by mode and doesn't go on nor does it later
Pulled the plug and plugged back in. Turned off power button, held the reset button, turned on tv. tv turned itself off and back on. I then releashed the reset button. The screen did not come on.
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Dec 21, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
3972
Points
28
How many times does the standby light flash...b/4 pausing and repeating ?
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
I have a sharp aquos lc-70le650u, will not turn on, power light flashes rapidly 2 times then 5 times
I'm not sure about this one since I never worked on 1 of them.. But I did find a link that you can check on. http://www.badcaps.net/forum/showthread.php?t=41773. Good luck on it
Panasonic TX-L42S10B has power but won't turn on
ok, this may be a silly question but when you turn it on and it starts flashing red, have you tried pressing the stand-by button on the remote. if a tv has been put on stand-by by the remote, and is then switched off by the set, when the set is turned back on it is still in stand-by mode and you need to press the stand-by button on the remote.
other than that I don't know.
TV won't work after storm
ok lets try this hit the power button on the DVD player some go into stand by mode and when power is interrupted you have to push the button manually also reset the surge protector next get a lamp that you know works and unplug the tv and plug the lamp into the socket where the TV was plugged into turn on the lamp, does it turn on? yes then something wrong with TV again may have been in stand by mode plug back in and try pushing the power switch on make sure the TV if it has a remote is on the right im put to get a picture say like a satellite or cable or DVD player. hope this helps.
1helpful
TV powers on but NO screen pops on.
1 check remote control. 2 tv comes to stand by to protect itself 3 there might be problem in power supply section 4 & if it is ok check horizontal section. 5 call skilled tech to fix it. 6 it is not a major problem.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
