This is the childproof lock symbol and prevents you from changing a program once it has been selected The symbol flashes if the program is changed during a wash cycle. If the machine is switched off mid cycle with the lock on then it will continue the program as so as the machine is switched back on. To activate the lock press the START button and hold for 4 seconds and the key is displayed. To deactivate the lock press the START button and hold for 4 seconds until the key symbol disappears.
Your washer is in the
"child lock" mode, hence it won't allow any program. Press the "menu" button until you
see "CHILD LOCK :ON" appear in the display. If nothing is pressed within 10 seconds.following
this the menu will close and it will default to program in the display. Once you see that in the display, press the
"select" button until "CHILD LOCK :OFF" appears in the
display. Finally by pressing the
start/pause button the key symbol should disappear - confirming you have
successfully exited the child lock program.
Pl click if helped.
