I have a dometic #2862 rv refrigerater which is freezing everything solid on both gas and electric. I have just installed a new heater element( supposed to be the right one) took the rv out for the weekend and now everything is freezing.???? was working A1 on gas prior to installing new heater element.
SOURCE: heat strip installation
It was quite simple, just installing the heat strip and my model only required removing the grill cover and mounting the element. The other optional installations didn't apply to my model.
thanks,
Don
SOURCE: Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
SOURCE: Dometic DM 2862 Too Cold Freezing Everything
don't worry! just switch off your refrigerator for 8hrs than switch it on......place the thermostart at 3 point......i'm sure that your problem will be solved. if not than replace your thermostart..................have a nice day:-)
SOURCE: Dometic 3 way RV ...the igniter strtrer just keeps
sounds like thermocouple needs replacing..easy job ? if you know what to do....
SOURCE: trying to purchase a heating element for a Dometic Dm2652
Try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673. there not a dealer just a service department, they might be able to help.
