Ice maker wont dump ice. it will refill with water after i press the test switch, but wont dump ice until i hit test switch again.
You
have two sides to the water control valve. One side is for the water coming from
fountain and the second side is to refill your ice maker after each cycle of
dumping ice into the ice bin. The freezer should be a 5 degrees or below for
the ice maker to function properly. If the ice maker is empty then fill with
tap water up to top edge of the ice maker and allow to freeze. If after the
water freezes and dumps the ice into the ice bin the ice maker does not refill
I would recommend replacing part=> 67006009 Dual Water Control
Valve
or here=> 67006009 Dual Water Control Valve
If the ice maker has old ice inside and does not want to dump itself it will be considered defective and the ice maker core moduel will need be replaced=> W10190972 Ice Maker Assembly
Whirlpool Ice Maker Troubleshooting
I will be here
should you have any questions, Thank You, Sea Breeze
Please Rate this Solution
